Question about Makita 10" Miter Saw LS1030N
The only way to turn the saw off is to unplug it. Ryobi 10 inch sliding compound miter saw model TSS100L
After using the saw a couple of times it sticks in the on position and the only way to turn it off is to unplug it.
  • Makita Master
  • 885 Answers
You may be able to take the handle apart and, using compressed air, blow any sawdust out of the handle and switch but most likely you'll have to replace the switch.
Posted on Apr 28, 2014
karmacanic
  • 16 Answers
SOURCE: Frozen slide mechanism
lubricate it with graphite powder OR silicone spray lube but not both
Posted on Oct 27, 2008
SOURCE: makita LS1013 compound saw wont slide,instruction
You may find, you have a lock, button, that needs to be held in, before you can drop the saw to cut.
Posted on Apr 28, 2010
rowdy45176
  • 2176 Answers
SOURCE: I have a Makita LS
check position 79 the spring that pushes against the table and also the end of the locking knob to make sure not rounded over/worn not applying pressure to the locking spring.
Posted on Dec 22, 2010
  • 17 Answers
SOURCE: i need to know where to adjust my 10 inch kobalt miter sliding saw for a true 45
Should be in the back of the saw wher it pivots
Posted on Mar 22, 2012
stug_57u
  • 99 Answers
SOURCE: change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Posted on Jul 23, 2012
Ryobi compound miter saw stopped working, smoked a bit, and blew a fuse. Now it turns on, laser works, but does nothhing when you hold the trigger down. What now?
Could be one of the field coils have gone open circuit when the fuse blew. You might also have an armature problem that caused the problem in the first place. You will have to strip the tool and examine armature and field coils. use multimeter to con check windings.
Nov 06, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Ryobi TSS100L blade guard spring
I think what you are refering to is a circlip washer , and can only be
fitted with ( CIRCLIP PLIERS ) do you know any Michanics or Engineers as they are bound to have a set in their toolbox ,on the other hand you
can buy them. What they do is work in the opposit way normal pliers do
when you squees the handles together the jaws open,therefor opening
the (CIRCLIP ) and allowing you to place it over the pin and into the
recess. Hope this has been of some hellp goodluck T.C.
Mar 29, 2013 | Ryobi Saw. 13 Amp 10 in. Sliding Compound...
Can i get guard for 10" miter saw
Go to www.ereplacementparts.com and search on your model to get a parts breakdown. Use TS1342L as the model number, the ZR indicates it's reconditioned. You can order parts from them or get the part numbers for the parts you need and check the internet for other vendors that may have better prices.
Feb 25, 2011 | Ryobi ZRTS1342L Factory-Reconditioned 14...
I have a Ryobi 10" sliding compound miter saw with
No i have a hatachi 10 inch miter saw with laser it dosn't work the laser if your in the light. If the sun is out you can't see the line so use it in the shade and see if it works and i use mine a lot its a grate tool if not you may have a problem with the conection but then i have been moveing away from ryobi tools they used to be realy good but home depot has kind of draged them down. Now they make the tools for home depot to there speic's
Dec 20, 2010 | Ryobi 10 In Miter Saw With Laser
What is the middle of the road, good Compound Miter Saw? I want to replace all of the baseboards & door trim in my house. I want to do a good job of it.
I have a chicago tools 12 inch sliding compound miter saw that I'm pretty happy with. I got it at Hatbor freight on sale for $119.99 plus tax. Regular $199. I'm favorably impressed with the quality of workmanship and ease of use.Expecially at that price. I Also have a very good 10 inch black and decker but it is not compound. Hope that helps.Thanks
Nov 13, 2010 | Ryobi Saws
My saw is really stiff when you try to change the angle .I oiled it but this didn't help. I would like to know how to take it apart but I am un sure how to do it and what is in the boxed off area...
Exploded diagram with parts list for LS1016 10" Dual Slide Compound miter saw is here.
Owner's manual is here. If these aren't quite what you need, you can view other models of Makita miter saws, here.
One thing to bear in mind. There's a miter angle lock and a slide lock on the bottom front of the saw. If you don't have the miter angle lock loose enough, it will be difficult to turn the saw.
If this answer was useful, please vote for it. Thanks!
Apr 14, 2010 | Makita 10" Dual Bevel Sliding Compound...
Oct 27, 2008 | Makita 10" Dual Slide Compound Miter Saw...
Makita 10" Miter Saw LS1030N Logo
154 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
