Question about Maytag Atlantis MDE7400AY Electric Dryer
Blower wheel bad on may tag dryer
How do you replace a screed on blower wheel on a Maytag gas dryer
    Problem Solver:
  • 10 Answers
Anything involving gas have a certified technicien to do it,anything goes wrong your safety is at risk
Posted on Apr 14, 2014
  • 131 Answers
SOURCE: Maytag dryer
Hmmm. No answer a week later? You called "Tears," didn't you?
Posted on Mar 17, 2008
  • 1028 Answers
SOURCE: how do I replace a
lift top remove front panel
Posted on Jul 23, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Maytag dryer won't rotate after blower wheel replacement
The dryer belt may have broken or come off its pulleys. Pop open top of dryer or rear vent door to look inside to see if this is your problem. Let me know if I can help, Thanks Sea Breeze
Posted on Mar 19, 2009
  • 142 Answers
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Posted on Jun 03, 2009
heatman101
  • 43501 Answers
SOURCE: May tag gas dryer don't get hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Aug 15, 2011
Screeching sound coming from Maytag dryer. Blower wheel, motor?
Probably bad motor if dryer is shutting down after few minutes of operation
Aug 27, 2017 | Maytag PYG2300A Gas Dryer
Problem with the Maytag Neptune MDG6700A Gas Dryer WHEN STARTED HEATS UP THEN NO HEAT AT ALL. MAYTAG MDG6700AWW
Hello & Welcome to FixYa
When the dryer heats for few minutes and then it won't work it means that the thermostat is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this part for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDG6700A Gas Dryer
My Maytag Neptune gas dryer has an error code hE and is not heating up.
Hello and Welcome to FixYa
When the dryer wont heat up and dry clothes it means that the thermostat is bad and needs replacement. This part is located on the blower wheel housing inside the duct, please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDG9700A Gas Dryer
No heat on Maytag Atlantis Gas Dryer
Hello
Kevin
Nov 11, 2010 | Maytag Atlantis MDG8400AW Gas Dryer
MaytaG MODEL # MDG4000BWW. Rumbles and sweels as
check the rollers,the pulley and if it shakes as bad as it sounds the blower wheel is probably damaged
Jul 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer starts slow with rrrrrrrrrr noise and timer does not move
This could be a simple repair. The blower wheel in the exhaust housing maybe free spinning on the shaft. If it is replace the blower wheel. If not the motor has gone bad.
Feb 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Rumbling noise in maytag gas dryer DG110 series 01
Unplug Dryer first: Page 3-11 of full service manual at link below will get front off. The most common solution for your problem is the blower wheel loose on the shaft. Hold drum and see if you can turn blower wheel (lower left plastic squirrel cage) separately. If you can turn the plastic wheel while you hold drum still, replace blower wheel.
http://www.servicematters.com/maytag_library/docs/16008714.pdf
Aug 22, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Neptune Gas Dryer MDG9700AWM fire comes on then shuts off after a few seconds. I have replaced the coils as well as the thermostat (part #20) if I just move the thermostat away from the burn tube...
TAKE THE FRONT OFF THE BLOWER WHEEL- THE METAL COVER ON THE BOTTOM LEFT CORNER- CHECK THE PLASTIC WHEEL INSIDE - THE CENTRES OF THE WHEEL WEAR OUT
ALSO CHECK THAT ANY EXHAUST DUCTING IS CLEAR
Jul 10, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
41 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
