Question about Husqvarna Garden
Lube Cap Won't Unscrew
Bought my chainsaw from Amazon.com. During assembly, was checking out the machine to familiarize myself with it. Tried to unscrew the lube cap and it wouldn't budge. Do they have King Kong putting those caps on at the plant?
    Sergeant:
  • 166 Answers
It's a sales pitch to increase the sale of 24" pipe wrenches.
Posted on Feb 14, 2014
jgwhomeequip
  • 1902 Answers
SOURCE: Chainsaw Bar Lube Oil Leaking
A new mounting bar would solve this issue. On that mounting bar there is a little piece that allows oil to drop onto the bar when you call for it or if this is a electric bar oil chain saw. Then it tracks when it needs to open.
Posted on Feb 14, 2009
dontbother10
  • 2220 Answers
SOURCE: Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Posted on Oct 07, 2009
Testimonial: "thanking you"
  • 221 Answers
SOURCE: PoulanPro PP3516AVX gas cap will not go in and close properly
I hate to say but you need two caps or run non ethanol fuel. There are a few gas stations around that still sell it. I keep a can around for the saws. What I do is run one and let the other sit in the sun and dry. I can usually use one all day before it swells.
Posted on May 06, 2010
  • 420 Answers
SOURCE: poulan chainsaw 18" 42 cc, pro gas filler cap?
Yep they swell after a while and will not screw in or out!
Sand the threads down so that the circumference is reduced with a course file or plumbers cloth, chamfer the threads a bit on the edges. A new one will do the same thing after a while so just fix the one you have.
Posted on Jun 14, 2010
SOURCE: Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Posted on Jul 02, 2011
I bought a book on Amazon. My Alexa does not read it. Do I need to buy this book again on Amazon Audible?? The book is Eat Fat, Get Thin by Dr. Mark Hyman
Not familiar with what Alexa can do. I see it is word to speech enabled but never tried that. Here are ways to contact customer service.
To contact us via phone:
http://www.amazon.com/clicktocall
To contact us via chat:
http://www.amazon.com/clicktochat
Dec 09, 2016 | Amazon Tablets & eReaders
The brushes won't turn, and cleaning the filter (as suggested in the owner's manual) doesn't help.
Hi ken wright.
Remove the bottom of the head of the vacuum...remove the roller brush assembly.
Clean the assembly...remove the end caps and clear all hair,strings,etc from the end cap and rotating brush head.
After cleaning the brush head and bearings, lube the bearings with a good grade of machine oil such as 3 in 1 oil.
Check your belt condition.
Reassemble and you should be good to go
Please take time to rate me
Sep 05, 2011 | Vacuums
How do I get the cap off neutral drain assembly to clean out drain lines without damaging it . i need to clean out lines I believe they are clogged. It is displaying F-21
To check the pump filter for blockage, remove the panel underneight of the door,the pump will be in right lower corner,unscrew the big(about 4 inches diameter) white cap just a little and use towels to catch water that comes out of it,when all water out completly ,unscrew and check for blockage.
Gene
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Stalls at full power.
Chainsaws run a little on the rich side when free running, this additional fuel is then used drawn upon when the saw goes under load, so i would say it is running a bit on the lean side, you need to make an adjustment to the H mixture screw on the carb, unscrew the screw approx 1/2 turn and see if this makes it any better.
Feb 10, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I bought and assembled telescope but we are new to telescopes and cannot see anything. I put the lense in correctly. I pull out the bottom cap and can see myself in the mirror within the tube. On the...
POINT THE END with the cap toward the sky. The mirror is on the bottom of the scope. Then put the eyepiece with the largest number written on it into the focuser, practice focusing on a distant object during the day time.
Nov 12, 2010 | Meade 114EQDH4 (36 x 114mm) Telescope
I have a WH15664 which all of a sudden the gooseneck spout stopped completely. My sprayer works fine. There is absolutley no water comming out of the spout. I can not understand why. can you tell me what...
Try cleaning out the aerator assembly. Not totally familiar with model but the cap end of he gooseneck should unscrew or you may have a screw in insert. If cap unscrews, carefully try to remove the screen and flow reduction insert and clean thoroughly and replace. If cap end does not unscrew look at head where water would normally come out. If notice raised ribs and notches see if you can use a straight edge to un screw the aerator. They make special wrenches but I can remove mine with a butter knife edge. If you get water with aerator removed it's definitely clogged up. I've bet this is the case as sprayer and spout are typically ported from same point in faucet assembly. I had a tennants garden tub faucet that did the same thing and the aerator on the spout was clogged with trash.
Dec 29, 2017 | Whitehaus Plumbing
Maytag top load washing machine model LAT9306AGE.. the timer doesn't spring back out when needed to during cycles
the timer on all maytag's ( top load turn clock wise/ push in to stop/ pull to start . the spring back ??? the timer shaft may be sticking and is hard to turn . remove face cap and clip pull dial and lube with a light oil or spray lube / reinstall and this moy help .. mm
Dec 02, 2009 | Washing Machines
How do you take off the Pannarello steam attachment to install the Cappuccinatore? Does it screw off or does the entire unit pull off. I've tried some force but I don't want to break the Pannarello. Thanks
Hi
Most pannarello's have a screw cap on top. The outer shell pulls off with a twist. Hold the inner stem and twist the cap on top to unscrew. Leave the cap and seals on the wand, or just loosen the cap and pull the whole assembly off complete, or you could loose parts that are inside.
Oct 24, 2009 | Gaggia Titanium Espresso Machine
Chain Lube Leak
It is the nature of the beast. Many chainsaws suffer from this malady. I own a bunch.
Lou
Try loosening the oil cap prior to bed.
Aug 04, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain Lube Pouring Out of Chainsaw
We can see no more detail than can you.
This is a collection of chainsaw enthusiasts that may provide a better answer. Be prepared for a little grief because you a Poulan.
ArboristSite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9
GL
Lou
Feb 22, 2009 | Poulan Garden
Garden Logo
41 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
