Question about Polar PIM15W Ice Cream Maker
Haven't used in 8 months when plugged in a little water starts running and the lights come on then nothing happens. first time i tried it a few cubes were make but nothing since
How many ounces are in 8 cups of water
2 Quarts, 64 ounces
How many ounces make 8 cups of water??!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid=20110510124322AATVk3D
May 10, 2011 - 8 cups is 2 quarts or 64 ounces and no you do not HAVE to drink 2 quarts of water to be healthy. You do have to drink enough to not be ...
How many cups are in 8 ounces of water? - Quora
https://www.quora.com/How-many-cups-are-in-8-ounces-of-water
There are exactly 8 fluid ounces of water in a cup. However, that same water weighs just over 8 ounces avoir du pois. (8.3454) This depends a little on ... how many ounces are in 8 cups of water Google Search
Aug 17, 2017 | Ice Cream Makers
Tip
Use you ice cream maker to Starting Solids with an Exclusively breasfed infant
Problem: You want to let you little one try solid foods but you don't want to add other foods to their diet yet.
Solution: take a bag (8 ounces or so) of expressed breastmilk and run it in your ice cream make. This gives you a solid texture to let you little one try and learn to eat without compromising the nutritional/developmental value of breastmilk.
on Jan 09, 2010 | Ice Cream Makers
What is the recipe of Indian kulfi?
Kulfi Recipe
  • Prep time: 5 min
  • Cook time: 90 min
  • Serves: 5
Main Ingredients:
  1. full fat milk
  2. sugar
Ingredients
  • Full fat milk - 1.25 lts
  • Powdered Sugar - 1/3 cup heaped
  • Cardamom - 4, powdered
  • Pistachios - 8, roughly chopped (optional)
  • Saffron - few strands, soaked in a tbsp of warm milk for 10 mts
Method
  1. Heat milk in a wide bottomed pan and bring to a boil. Allow the milk simmer on medium flame till it reaches half its original quantity. Keep stirring inbetween.
  2. Add powdered sugar, cardamom powder and roughly chopped nuts. Mix well and keep simmering on medium flame, stirring till it further reduces to almost one third of its original quantity. It will have a rabdi consistency and slightly thick.
  3. Turn off flame and allow to cool.
  4. Once cool, place the mixture in the fridge for a few hours. (This helps reduce formation of ice crystals during freezing process)
  5. Pour the chilled mixture into kulfi moulds and close the lids.
  6. Place the kulfi moulds in the deep freezer and allow to set overnight or at least 7-8 hours.
  7. Once the kulfi sets, place the kulfi mould in luke warm water for a few secs to help it unmould easily.
  8. Insert kebab or ice cream stick in the kulfi and serve. You can garnish with more nuts.
Tips
  • Full fat milk is essential for authentic flavour of kulfi.
  • If you do not have kulfi moulds, you can use stainless steel vessels.
  • Kulfi expands on freezing, so do not fill to the brim.
  • You can skip step four and pour the milk mixture that is at room temperature into the kulfi moulds.
Dec 25, 2015 | Ice Cream Makers
Nostalgia Electrics Ice Maker Troubleshooting
My Nostalgia Ice maker shows low water, but there is water up to the fill line.
Mar 10, 2014 | Nostalgia Electrics RIC-100 Retro Series...
I plug it in and nothing happens with the motor, no hum no nothing on ice cream maker 8550 been sitting for a year and not abused. is there a switch ? the thing will turn by hand , or is there a safety...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 23, 2011 | Rival 8550-X 5 Quart Ice Cream Maker
I took apart a Taylor 430-12 Frozen Margarita machine and need help on trying to reassemble it...
Taylor 430, craziest issue. Liquid is not flowing in hopper all the way. It stops and starts bubbling at the top. Nothing is blocked, reassembled several times with/without face plate. The water will only go halfway in the hopper. No type of blockage. can someone offer any ideas, suggestions. Im lost
Oct 09, 2010 | Taylor Ice Cream Makers
No accumulation of ice
Check to see if your condensor coil is clean, use an air compressor or other source to blow thourgh the coil,dont just brush it off. newer refrigerant charged systems need as much air flow as possible to work ,also make sure the cover is on the condensor section while the ubit is in nrmal operation. try setting the cube size to lowest setting and let run for 24 hrs. Let me know if you need further assistance.
Nov 16, 2008 | Ice Cream Makers
Emerson IM90 Portale Ice Maker
My friend bought this item last week at Target for the $99 sale price. The reviews were all horrible about the red light (add water) indicator going on after the first or several first ice cube runs and never going out. About 40 out of 60 reviewers had this problem. We experienced it right after the first run when the ice cube full light went on. We emptied it and the add water red light was on. I looked all over the web for a solution and only found one that suggested tilting the unit backwards for 45 degrees and that would magically reset the light. It did not after several angles, light taps and basic shaking. Since there was no alternative and everyone who returned it also got the exact same problem with the new replaced model - we decided to open it up and investigate.
The electronics diagram is on the back of the machine and tell you where the water indicator is. We took it out (an inch long black tube along the water pump and backflow valve) and dried it completely. The cycle still had the red light. We submerged it completely in water and the red light still went on saying that the unit needs water. We determined that this is the bad part and the water indicator is faulty. We cut it out and joined the two wires. IT ALL WORKS NOW FLAWLESSLY. You only have to shut the unit off when you leave since it will ocntinue to run if out of water. If you're looking for a quick mechanical fix and have a unit that works when you need it and you are around - this isthe fix.
Aug 23, 2008 | Ice Cream Makers
Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Jun 21, 2008 | Polar PIM15W Ice Cream Maker
Ice Cream won't set up
Carri, Can you provide more information? What did you change in the recipes? How old is the machine? What was the temperature around you? Did you run three batches or more right in a row? -j.
Jun 19, 2007 | Rival 8704 4 Quart Ice Cream Maker
Polar PIM15W Ice Cream Maker Logo
27 people viewed this question
Top Polar Ice Cream Makers Experts
Andrew Taylor
Andrew Taylor
Are you a Polar Ice Cream Maker Expert? Answer questions, earn points and help others
