Question about Vehicle Parts & Accessories
Replace key ignition on 2000 mercury mystique
  • 2,760 Answers
Doe you want to replace the key or the switch because the two are not same part , key is inside steering coulum just behind the steering wheel ,, switch is on top of steering coulum under dash they are about 12 inchs away from oneanother ?
Posted on Apr 04, 2014
Replace front wheel bearing on 2000 mercury mystique
you will need a bearing press to change bearing or you can buy it as a compleat assembly below is a download of directions
Sep 25, 2014 | Cars & Trucks
2000 mercury mystique turns over but want stert
check for fuel rail check for spark you can hear the pump run when key is turned if know sound is heard check fuse,relay,pump. get spark roll over check for spark if no spark pull out mod take to autozone to have tested if good replace crank sensor
Aug 15, 2012 | 1998 Mercury Mystique
How to replace front wheel bearings in a 2000 Mercury Mystique?
Travis, this Mystique has sealed wheel bearings, you do not pack them with grease. You cannot even access the bearing. If you are not familiar with a car, you do not know if you are giving correct directions or not.
Feb 11, 2012 | 2000 Mercury Mystique
My 2000 mercury Mystique wont start when i turn the key in the ignition is just clicks what could it be alternator starter or battery?
first check battery voltage. should be 12 volts or a little over. IF the battery is low then charge battery and then load test battery. If you remove you battery and take it to local parts store most will check for you. if battery load test good but was low on voltage then I would check to see that alternator is charging while engine is running. should be charging aprox 13.9 volts. if battery had full voltage and load tested good then most likely the starter is bad.
Jan 16, 2010 | 2000 Mercury Mystique
How to program remote key of mercury mystique 2000
I am assuming this is the factory key fob.
Read all instructions before attempting.
FORD KEY PADS/REMOTES
  • Insert key, turn ignition off-to- on eight times in succession, ending with key in on position doors will lock, unlock to verify in programming mode
  • Press any button on new remote, doors will lock, unlock to verify
  • Do the previous step with the second remote, doors will lock unlock to verify.
  • Turn ignition off. Doors will again lock, unlock to verify.
Dec 23, 2009 | Mercury Vehicle Parts & Accessories
I have a 2000 Mercury Mystique IT is not wanting to start once I get it started it runs fine but it is getting harder to start
if it seems to be turning over slower than you remember, when it was easy to start . the bushings in the starter are probably worn allowing the armature to make contact
with the field coils in the starter case.
this then causes a severe amperage draw on the battery,which in turn drops the voltage to computer and ignition circuit below 12 volts while cranking
Nov 12, 2009 | 2000 Mercury Mystique
2000 contour
for 98 contour issue. TSB 98-21-14 not covered by warranty
This TSB article is being republished in its entirety to include the 1999 Cougar . ISSUE: The ignition key may be difficult to insert or remove and/or key chimes may sound with the ignition key removed and driver's door open on some vehicles. This may be caused by internal design characteristics in the ignition lock cylinder increasing insertion/removal efforts which may allow the lock cylinder to stick.
ACTION: Install a revised ignition lock cylinder. The revised ignition lock cylinder should reduce the possibility of high insertion/removal efforts and ensure proper chime function. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
  1. Verify customer concern.
  2. Observe the ignition lock cylinder as the key is removed. If the lock cylinder snaps outward to the non-depressed position and the chimes stop sounding, continue to Step 3. If it does not snap outward, replace the ignition lock cylinder with the appropriate cylinder by referring to the Parts Block in this article.
  3. Insert and remove the ignition key from the lock cylinder. If binding or high efforts are encountered, replace the ignition lock cylinder.
  4. From the Parts Block, select a lock cylinder with a part number suffix identical to the center character of the key code of the vehicle. The suffix must match the center key code character to maintain a single key system.
  5. Install the replacement lock cylinder, by referring to the 1998 Contour/Mystique Workshop Manual, Section 211-05 or the 1999 Cougar Workshop Manual, Section 211-04. NOTE: KEYS INCLUDED WITH NEW IGNITION LOCK CYLINDERS ARE CUT FOR THE IGNITION ONLY. IN ORDER FOR THE KEYS TO FUNCTION IN THE DOOR LOCKS, THE KEYS MUST BE CUT TO THE DOOR CODE OF THE ORIGINAL LOCKSET. THE KEY CODE WILL CHANGE UPON INSTALLATION OF THE REPLACEMENT LOCK CYLINDER (FIGURE 1).
    Figure 1 - Article 98-21-14
    NOTE: ADVISE THE CUSTOMER TO DISCARD ALL KEYS THAT WERE CUT TO THE ORIGINAL IGNITION LOCK CYLINDER.
  6. Record the new key code on the repair order and provide to the customer. Advise the customer to record the new key code in a permanent location and to discard all references to the original key code. NOTE: REPLACEMENT IGNITION LOCK CYLINDERS ARE SHIPPED WITH NON-PASSIVE ANTI-THEFT SYSTEM (PATS) KEYS. IF THE VEHICLE IS EQUIPPED WITH PATS, OBTAIN TWO (2) ROTUNDA KEY BLANKS (OR OTHER FORD AUTHORIZED BLANKS, SUCH AS: ILCO, STRATTEC, CURTIS, HUF, OR VALEO) AND CUT TO THE REVISED KEY CODE. USE OF OTHER UNAUTHORIZED KEYS MAY CAUSE ERRATIC OPERATION OF THE PATS SYSTEM.
  7. Program PATS keys using one of the two following methods:
(1) For vehicles with Integrated PATS (IPATS), function built into the Powertrain Control Module (PCM) and built beginning:
  • 2/2/98 Kansas City (Contour/Mystique)
  • 2/16/98 Mexico (Contour/Mystique)
  • All 1999 Cougars
Using the New Generation Star (NGS) Tester equipped with Service card (green) level 3.0 or higher:
  1. From NGS menu, select:
    • Service Bay Functions
    • PCM
    • Enter Security Access (10 minute delay)
    • Ignition Key-Code-Erase
  2. Disconnect Data Link Connector (DLC).
  3. Cycle the first non-programmed key in the ignition to run position for at least 3 seconds and then turn to the off position.
  4. Cycle the second non-programmed key in the ignition to run position. The theft indicator should prove out for 3 seconds.
  5. Verify the vehicle will now start using both keys.
(2) For Contours/Mystiques with Stand Alone PATS and built before:
  • 2/16/98 Mexico
Using the New Generation Star (NGS) Tester equipped with Service card (green) level 1.0 or higher:
    • PATS
    • Ignition Key-Code-Erase (this process may take up to 8 minutes to complete )
  2. Disconnect DLC.
  3. Cycle first unprogrammed key in the ignition to run position. First key will program and allow vehicle to start.
  4. Again cycle first programmed key to run position. Within 15 seconds, remove original key and turn new unprogrammed key to run position. The theft indicator should prove out for 2 seconds. New key will start vehicle.
  5. Repeat this process for additional key programming. NOTE: THE FOLLOWING SHOULD BE NOTED FOR THE PART NUMBER BLOCK:
    • Part Number suffix will match center character in key code
    • Logo on key is Ford for Contour models
    • Logo on key is Mercury for Mystique and Cougar models
PART NUMBER PART NAME F5RZ-11582-A Ignition Lock Cylinder (Contour) F5RZ-11582-B Ignition Lock Cylinder (Contour) F5RZ-11582-C Ignition Lock Cylinder (Contour) F5RZ-11582-D Ignition Lock Cylinder (Contour) F5RZ-11582-E Ignition Lock Cylinder (Contour) F5RY-11582-A Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-B Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-C Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-D Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-E Ignition Lock Cylinder (Mystique, Cougar)
Mar 09, 2009 | 2000 Ford Contour
1997 ford contour
this is for 98, but may apply if yours is late 97 build.
Article No.
98-21-14
  • IGNITION SWITCH - HIGH EFFORT IGNITION KEY INSERTION/REMOVAL AND/OR KEY CHIMES SOUND WITH DOOR OPEN AND IGNITION KEY REMOVED
Publication Date: OCTOBER 15, 1998
FORD: 1998 CONTOUR LINCOLN-MERCURY: 1998 MYSTIQUE
1999 COUGAR
SERVICE PROCEDURE
  • All 1999 Cougars
    • PCM
  • 2/16/98 Mexico
    • PATS
  2. Disconnect DLC.
Aug 13, 2008 | 1997 Ford Contour
Vehicle Parts & Accessories Logo
43 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
