Question about Health & Beauty
Oster high velocity dryer repair
DOesn't blow hot
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
DLE330RAW amana dryer running too hot
The control thermostat on the blower housing is the one you need to change if it is getting too hot. It is taking too long to shut off the element. The only other thing it could be is a blocked vent making it overheat. The fuse is set for 350f the limit on the element is a 250 f one. I suspect the 250 f limit on the element is doing the drying not the control stat. Hence you getting overheat but not hot enough to blow the fuse.
Apr 13, 2013 | Amana DLE330RAW Electric Dryer
My Oster wafflemaker doesn't get hot! The lights are on but only gets warm
One or more of the heating elements are not activating. If you take it apart, perhaps you can do a continuity test on each element to see which is bad. I don't believe they sell element replacements so your only choice would be a new purchase or warranty.
Jan 29, 2013 | Kitchen Appliances - Others
Find a repair shop in fremont CA
Doesn't look like there are any in Freemont.
http://www.oster.com/ServiceCenters.aspx?state=California
Suggest calling Oster at 1-800-334-0759.
Sep 10, 2011 | Oster Blenders
Since Lakewood doesn't make fans any longer, any idea where I could pick up a couple of their 9-inch high velocity fans (new or used)?
Hi randy r metc...
I found one 9" High Velocity fan on ebay, it is new at a cost of $19.99 and free shipping.
Please take time to rate me
To see the fan go to the following webpage
http://www.ebay.com/itm/Lakewood-9-High-Velocity-Fan-1016-/320745163838?pt=LH_DefaultDomain_0&hash=item4aade6cc3e
Aug 18, 2011 | Lakewood High Velocity Fan 9 Inch
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
Dryer will not operate, Checked with a meter. There is 230 volts at the terminal block in the dryer.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 23, 2011 | Dryers
Dryer is taking longer to dry. what used to take 60 minutes now takes 90-120. I took off the back panel and the lint shoot. both were clean. The air blows out the duct with good velocity. Hot air comes...
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Feb 04, 2011 | Dryers
Dryer squeak and back panel is hot? Frigidaire Dryer FDE436RES1
It sounds like you have a rear bearing bad.
as far as over heating check the vent line. Your thermostats are ok or your high limit would blow and you would have no heat.
Sep 01, 2009 | GE DBXR463EDWW Electric Dryer
Fuse blowing
Your exhaust vent is blocked.
Timed dry is High heat.
Permanent press is a medium heat and intermittent.
The dryer does not get as hot as often in Permanent press mode. Therefore the fuse does not reach critacal and blow.
Remove the vent at the rear of the dryer and run a timed load.
If it dries correctly, repair your vent blockage.
If not, repost and I will lead you to the next step.
Feb 19, 2009 | Kenmore Dryers
Health & Beauty Logo
11 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
