Error code 0xc4eb8482
On initial turn on of HP Officejet 4630 I receive error code 0XC4EB8482
5 Suggested Answers
SOURCE: HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters Information It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured. From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
  3. Enter the parameter ____ on the key board and press the Check Mark.
    • 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    The screen will read Cfg param val: 26
  4. Enter in the value ____ and then press the Check Mark .
    • 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    Screen will read Test -001+
  5. Press the Reset button until you get back to Ready *
Posted on Oct 13, 2008
SOURCE: HP officejet/HP officejet pro J4680
What do I do to ron Faxs from the top instead of the window?
Posted on Jan 14, 2009
sanjay_tech
  • 20 Answers
SOURCE: HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Posted on Jan 26, 2009
SOURCE: error code i hp 4255 officejet printer
have problem in my printer hp officejet 4255 oll-in-one it give message ERROR : 0XF0aF8005 pleas help me I can repair the priter if u can diagnose the error code
Posted on Mar 05, 2009
HP 4630 printer has error code oxc4eb827f
Welcome to the HP Support Forums!
I see that you're getting the error code: 0xc4eb827f on the front panel of your HP Officejet 4630 e-All-in-One Printer. I'd like to assist you today with resolving this error. The failure itself may be within the print system in your printer. Due to the error state there is only one support step that we can attempt, which is a Reset. Can you please follow the steps below.
Reset the Printer:
Without turning off the printer, disconnect the USB cable from the rear of the printer.
Remove the ink cartridges from the printer. *
Wait until a message to insert the ink cartridges displays. If you do not see a message within a few minutes, skip to step 4 to disconnect the power cord.
Disconnect the power cord from the rear of the printer.
Wait 60 seconds.
Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
Reinsert the ink cartridges, and then close any open doors on the printer.
If you receive a prompt to print a calibration page, do so.
If you disconnected the USB cable, reconnect it to the rear of the printer.
Try to print.
Copy to Hp support.. hope this will help
Jun 20, 2017 | HP Office Equipment & Supplies
How do I fix TWAIN error? How do I fix Scan Gear error message cannot communicate with scanner?
you need to make sure that your printer is supported by TWIN , you can do that online.
Oct 21, 2015 | HP LaserJet Office Equipment & Supplies
How do i send a fax
User manual for hp officejet 4630
http://www.hp.com/ctg/Manual/c03909822.pdf
Chapter 6 contains all the setting details about fax.
The video showing how to send fax over telephone line
Oct 14, 2015 | HP Officejet 4630 e-All-in-One Printer
How do I copy 2 sided copy from 2 sided original on hp Officejet 4630 e- All-in-One Series
copy one side, then take copy and put back into blank paper try and then copy other side. trial and error will tell you how to put paper in paper tray but usually printed side up, top in
Sep 18, 2015 | HP Office Equipment & Supplies
Where do ink cartridiges go in an HP 4630 printer?
Download user guide from below link, you can understand how to load.
http://h10032.www1.hp.com/ctg/Manual/c03909822.pdf
Aug 25, 2014 | HP Officejet 4630 Inkjet Multifunction...
Hp officejet 4630 will not work with remanufactured ink cartridge
most wont.. they require the original expensive replacement cartriges..
Feb 02, 2014 | HP Office Equipment & Supplies
    • 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
Mar 04, 2008 | HP Officejet 9110 All-In-One InkJet...
jasbo
jasbo
