Question about Samsung SCX-4828FN All-In-One Laser Printer
Printing heavy bars or blank pages
Problem started with heavy black bars randomly across pages. Would intermittently print some pages fine. After discussing with Samsung support, I changed the toner and now it 'prints' blank pages. Do I need to clean something or is this a hardware failure that needs a technician to fix?
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 150 Answers
PLEASE REPLACE PRINTER LSU OR HIGH VOLTAGE POWER SUPPLY
Posted on May 08, 2014
4 Suggested Answers
  • 49 Answers
SOURCE: black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Posted on Oct 08, 2008
  • 30 Answers
SOURCE: black printing faded although toner not low
The black developer is defect, you have to call the service to solve this problem. and install FW Update V1.29.12.35
Posted on May 28, 2009
  • 670 Answers
SOURCE: Samsung CLX-3160FN Vertical lines when printing black
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Posted on Dec 24, 2009
My Printer started randomly printing blank pages when looking for color. Prints color every now and again, but generally blank. Prints fine when I set to Black/white only.
It is more likely that the settings need to be changed on a print job to job basis in the program you are generating the content from. There are usually defaults set in the software and you need to check these settings every time you print.
Mar 11, 2015 | Canon imageCLASS MF8170C All-In-One Laser...
What is wrong with my HP Deskjet D2330, and why is it printing only blank pages?
well it has got to be the ink cartridge. wipe of the bottom of it and make sure black ink shows up
Dec 10, 2014 | HP Deskjet D2360 InkJet Printer
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Hp Laserjet5: intermittent blank spaces, random
check the toner cartridge.. all the image formation occurs inside the toner ctg.. if you have quality issues try another ctg! Smiles
Mar 31, 2010 | HP Office Equipment & Supplies
Vertical lines of missing print
I'd certainly be swapping the fuser first although I know how expensive they can be and what a pain they can be to get at. You've tried everything else I would start with and as the text is smudging I'd certainly be testing the fuser next. Scott.
Dec 12, 2009 | Konica Minolta magicolor 2500 Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Hp laserjet 4250
try this
1.when the printer start print turn off the printer after the paper go on side the printer to make paper jam
2.open the printer and pickup the paper out slowly
3.see the print area on the paper if the black par appears on the paper that mean the drum unit faulty if not the fusser unit faulty
May 14, 2008 | HP LaserJet 4250n Printer
Resume button is stuck
i think you have aproblim with the main card in side the printer
Jan 11, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Colour lines across the page
Hey Paul, Can you post a scan of the printed paper? It may help diagnose your problem. The most common cause of lines accross the page is either the PhotoConductor Unit or the 2ND BTR Assy.
Nov 30, 2006 | Epson Aculaser C1100 Printer
Samsung SCX-4828FN All-In-One Laser Printer Logo
115 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
