Question about Copystar Ri-2530 Printer
Display says reset originals in processor but cant do anything to get out of it
How do l check if my samsung mobile is original?
Fake models are using MTK chipset and processors, check your processor model and chipset, if it's an exynos, snapdragon, qualcomm or anything else than MTK it's original.
Oct 20, 2016 | Samsung Cell Phones
I have a Sony KV-27XBR55 TV, that wont display signal (Video nor sound) it only displays 0 0000 on the Channel input
It sounds like you are in the service menu---aside from the zeros what if anything else can be seen?
The set does have (all Sony sets do) a reset done only with the original Sony remote.
Dec 21, 2012 | Televison & Video
Galaxy tab 10.1 frozen
Remove the battery and memory card, wait 60 seconds for the processor to reset, and power up.
Jul 11, 2012 | Samsung Galaxy Tab 2
My p5kpl-am mobo doesnt power on,last time, i change the processor, its ok but then ii put the original processor i doesnt power on anymore, what is the problem, is there anything to fix it
Hi
Changing the CPU may have corrupted the BIOS.
Disconnect the power cable , then remove the small silver CMOS battery for 2 minutes to reset the BIOS memory of the change of CPU., the try to power up again.
I hope this helps.
Aug 29, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
P4M900T-M2 Motherboard cant display anything on display, Power supply fan & CPU fan is running. I changed processor, RAM, Power Supply, Capacitors around CPU, but am still getting nothing on the...
It seem that changing the mother board was needed to confirm as there seems to be a problem related to non communication of the mother board with the CPU, RAM and sections.
Swap and confirm.
Aug 08, 2011 | Computers & Internet
Cant reset to factory out the box i try the 0 key it freeze on black screen with cursor. i recently install a windows7 professional and cant access internet and all the software including toshiba software...
Is still there Win7 working with your laptop ? As i can get you that you have reinstalled your Laptop with Win7 and you cant access your old software and setting from the original as it was shipped to you am i right ? And you want it back to reset to the old setting ? For that you can use the CD/DVD you might have got with your laptop ?
Apr 14, 2011 | Toshiba Satellite Laptop / AMD Turion II...
MCP61PM-HM mobo won't run long enough for os to boot
I'm assuming you didn't use the Cmos jumpers to reset the cmos and only replaced the battery?
Checked board to see if there are any capacitors bulging, leaking r blowing?
You don't say why you removed it in the 1st place? I'd remove it again and test it outside the casing, see if that solves the problem, then look inside the casing to see if there is anything that could be causing a short,
Other than that, you may have damaged a component on the board when you originally removed it
Feb 11, 2010 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
I have hooked up a switch box to are internet service .so I can use another computer but everytime i try to download or look at anything it says page cant be displayed or no connection .What do I do?
Make sure your original ethernet cable from modem is pluged into #1 port on your hub. reset modem by unplug then restart all PC's on your network. Good Luck.
Nov 20, 2009 | Microsoft Windows XP Home Edition
Copystar Ri-2530 Printer Logo
16 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
