Question about Unitec Gj 6200 Go-jak Right Hand Vehicle Dolly Caster Sold
Pedal on go jak 6200 hard to press down. also, when changing a tire can I put the tire on the go jak, wheel it over to the car and align the stud holes over studs and then fasten the lug nuts, so I don t have to physically lift tire to put it on the car.
How to fix 91 Mercury Sable Sedan right front wheel studs that have been sheared off?
tire shop or garage can press out damaged studs press in new studs.
Jun 17, 2013 | 1991 Mercury Sable
How to fix rear studs
,First,put block under front tires to keep from moving.If you have rear drum brakes,then you will need to remove hub,Jack up and secure,then remove tire,remove wheel speed sensor,if equipped.remove brake drum,bearing and spindle assembly.To remove stud and replace,you will have to turn bearing and align bad stud so it has room to be removed.get a hammer and a piece of wood to put over stud and knock out,don't use a piece of metal,could mess up end and make hard to get out.After you get new stud in ,get lug nut and tighten to pull stud in.A punch smaller than stud will work.
Aug 16, 2012 | 2001 Ford Focus
We have the lugs off the front tires of our 06 ford explorer and the tires won't come offf. What is the problem?
they can get stuck on the hub. just kick it or hit the tire with a big hammer and it will come loose.
Mar 25, 2011 | 2006 Ford Explorer
Hi haw can i change my wile Bering?
Park the car on level ground. Put the transmission in park and set the parking brake. Jack the car up and place the jack stands underneath the frame of the car.
Use the tire iron to remove the lug nuts from the wheel and pull the wheel off.
Use the ratchet set to remove the mounting screws on the disc brake caliper. Pull the caliper loose and then slide the disc off of the wheel studs.
Use the ratchet to loosen and remove the wheel hub mounting bolts located on the backside of the steering spindle.
Pull the entire wheel hub assembly off of the steering spindle. Take the assembly to a machine shop and have them use a hydraulic press to press out your bearing (the bearing is pressed into the hub assembly and is too big for at-home extraction).
Press in the new wheel bearings and then reassemble the wheel hub by mounting it on the steering spindle again.
Slide the disc back into place on the wheel studs and then remount the caliper with the mounting bolts. Slide the wheel back in place on the studs and tighten down the lug nuts in a star pattern.
Lower the car off of the jack stands or move on to change the other side's wheel bearings as well.
Oct 20, 2010 | 1991 Honda Accord
I have a broken wheel stud on left wheel of a two-wheel drive 2002 Envoy. How do I replace it?
TAKE VECHICLE TO SEARS AUTO CENTER OR ANY TIRE WHEELS BRAKE ALIGNMENT SHOP THEY CAN PRESS OUT THE STUD WITH OUT DAMAGING WHEEL BEARING.AND PRESS YOU IN A NEW LUG NUT STUD.PROBABLY CHARGE YOU $25.00 DOLLARS.
Jun 12, 2010 | Cars & Trucks
Change rear wheel stud
HELLO THERE:
WHEEL STUDS ARE PRESSED INTO THE WHEELS OR DRUMS BY A HYDRAULIC PRESS AND THEY CAN BE REMOVED THE SAME WAY OR THEY CAN BE REMOVED BY USING A SPECIAL SOCKET AND A SLEDGE HAMMER THEY COST ABOUT 3 TO 7 DOLLARS A SET OF 2 AND CAN BE BOUGHT AT ANY PLACE THAT SERVICES WHEELS AND DRUMS OK
hOPE THIS IS VERY HELPFUL FOR YOU
BEST REGARDS MICHAEL
Apr 14, 2010 | 1994 Mitsubishi Diamante
Broken rear wheel stud how do i repair it
The stud has to be hammered out if you don't have the tools to do this then I suggest you take it to a tire shop they don't charge much. depending if it's front wheel or rear wheel drive will determine what has to be done. If it's a rear axle they will remove the tire and drum and knock out the old one with a hammer and punch and replace it with a new one same size, they can hammer it back in our use washers to pull it into place this is the same on the front wheel. You will need to measure the bolt to get the right length and width. tire shop will have the stud you need.
Sep 11, 2009 | 2002 Dodge Caravan
1986 Audi 5000s tire change instructions
jack car up, put on jack stand,,remove wheel studs/bolts unbolt studs,,remove old wheel replace with new wheel.
Jan 16, 2009 | 1986 Audi 5000 CS
Wheel Stud
If you remove the wheel drum you can knock out the broken stud. It is pressed into the hub. Take the hub to aan auto parts store ( so you get the same size stud) and buy a new stud. put the stud into the hole in the hub. When you remount you remount the tire and tighten the lug nuts that will pull the new stud up tight in the hub.
Hope this helps
Good luck Loringh
Oct 18, 2008 | 1996 Kia Sephia
Unitec Gj 6200 Go-jak Right Hand Vehicle Dolly Caster Sold Logo
44 people viewed this question
Top Unitec Tools & Hardware - Others Experts
john h
Are you an Unitec Tool and Hardware - Other Expert? Answer questions, earn points and help others
