Question about Ford Toys
How to unstick gears in model 1700 ford tractor
Stuck in 4th gear
  • 34 Answers
SOURCE: 2001 Triumph Legend Stuck in 4th gear
this is most likely a bent  or broken shift fork  a broken gear cluster  or  foreign object lodged in the transmission housing  this is very complicated repair and should not be attempted buy untrained mechanic it can also be costly repair
Posted on Feb 16, 2009
  • 218 Answers
SOURCE: Ford 8N has a broken tooth/teeth on ring gear. How
Hi..my name is Keith..and i restore 9N's,2N's and 8N's....and to replace the ring gear..you split it there at the back of the engine..and its kind of a big job..so i would check the starter 1st..to make sure its not a starter problem..i hope this helps..if not please write back..i love tractor problems
Posted on Jul 09, 2009
  • 273 Answers
SOURCE: Clutch Malfunction and Adjustment
check clutch cable it could be either stretched or snapped if not you need a new clutch
Posted on Aug 12, 2009
  • 221 Answers
SOURCE: press clutch , put tractor in gear , let out on
Will require you to split the tractor and repair the clutch. Sorry.
Posted on Sep 08, 2010
  • 63 Answers
SOURCE: On my massey ferguson tractor 255 The clutch
Try rocking the thing back and forth with someone pulling on the shifter at the same time.
Posted on Oct 09, 2011
Yamaha V Star 1300 starts but immediately shuts down went put into gear with clutch in
clutch plates stuck keep motor off put in high gear like 4th and push back and forth till plates unstick make sure kick stand is up
Jul 19, 2014 | 2007 Yamaha V Star 1300
Transmission
I am guessing an automatic. Drain the tranny and clean the governor. Replace and refil the fluid. Inexpensive if you reuse the fluid and not too time consuming.
Apr 26, 2014 | 1993 Ford Ranger SuperCab
Manual Trans. stuck in gear
sorry only a transmission shop can help you .
Sep 24, 2017 | 1996 Ford Explorer
Shifter is stuck in 4th gear and wont come out. I was having problems getting in some gears at first and then it was getting stuck in 4th but would come out, now it stuck and wont come out.
Will it come out of gear with the engine shut off? When you were having trouble getting it into gear was it with the engine running? If you answered yes to either, or both questions then you likely have a clutch problem; faulty clutch assembly or slave and/or master cylinder. If the problem occured with the engine off then you have internal transmission trouble.
Apr 18, 2011 | 1995 Ford Ranger Supercab
Can not remove starter
You mean you cannont physically take it out. Is the starter drive bound up with the ring gear? If thats the case put the tractor in high gear and rock it by pushing on a rear tire to unstick the drive... Need more info.
Aug 20, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
TRANS. JAMMED,STUCK IN 4TH GEAR
i bet it has been making a growling noise for a while ? Whats going on now is the main shaft bearing has siezed on the shaft and or broke the shaft ,your best bet is to find a used tranny fixing your will cost more then a used one
May 29, 2009 | 1989 Ford Ranger
Toys Logo
Top Ford Toys Experts
Philip Doherty
Level 1 Expert
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
