Question about Schwinn 420 Elliptical Trainer
How to take off wheel cover
Need to replace small black motor. Replacement sent by Schwinn. Have outer cover off but can't get inner wheel cover off to reach motor
lemmingleejn
  • 173 Answers
SOURCE: Flat tire, S500
The wheel will have to be removed firstly.
Then with something blunt, (like a spoon handle, not too flexible, and smooth,)
carefully pry up the bead of the tyre over the rim of the wheel, now it's easier to take a second lever or spoon handle, and repeat the process, a couple of inches away from the first.
Then you should easily be able to run the smooth lever, around the tyre and rim, to expose the tube.
Then push the valve through the wheel, if neccesary, and remove the tube.
You should also inspect the inside of the tyre, thoroughly, to make sure that there isn't anything in there that shouldn't be.
After you are sure all is well, just reverse the procedure.
Just make sure that the tube does not get 'pinched' between the tyre and wheel.
Hope that helps.
Posted on Jul 24, 2009
SOURCE: I need a replacement inter
You might want to try these guys : http://www.scootercatalog.com/tubes.html
They sell a lot of the small tube sizes because they are used with the little electric scooters.
Posted on Feb 08, 2011
dunnbiker
  • 8546 Answers
SOURCE: I can not find a
Any bicycle shop.
Posted on Apr 12, 2011
dunnbiker
  • 8546 Answers
SOURCE: Need to replace crank arm on schwinn medirian 3
any bicycle shop should have chains and be able to assist with other issues.
  • 11 Answers
SOURCE: I need a replacement wheel
Its a regular 26 inch wheel. Just get a replacement, take the old one off and slide the new one on.
Posted on May 04, 2011
SCHWINN ROADSTER WHEEL REPLACEMENT
through your local bike shop. You may find these parts to be more than the price of a replacement
May 27, 2014 | Schwinn 12" Roadster Tricycle
What are the specs for my 1999 camry xle v6?
Search for diy wheel alignment. A trip to the alignment shop is bett
Apr 26, 2014 | 1999 Toyota Camry Tie Rod End Replacement...
Front pedals
Yes, you got the bolts too tight on the axle shaft. You have to "sets" of nuts, the inner and the outer. The inner nuts on the shaft, which go inside the fork, should be adjusted so the wheel is rolling freely, with just a tiny "slop". Now, you will need to figure out a way to tighten the outer nuts to hold the wheel on the fork without turning or moving the inner nuts! Some bicycle shops use specially thin wrenches.
Be blessed.
Aug 08, 2013 | Schwinn 12" Roadster Tricycle
I too have a clicking in the rear end, it has gotted worce. A scrssching noise now heard. Walking nent to it has not helped, appears to be internal.
It could be one of many things,The first Thing I would do is check whereabouts the noise is actually coming from,ie lifting the back of the bike up with a help of a friend and spinning the wheels one at a time and after both wheels being spun rotate the pedals and see if its coming from the gear cog at the rear,Whatever is the problem the part needs to be cleaned out and a new part put back on.It may be just a cracked ball race in one of the wheel spindles.
Mar 01, 2011 | Schwinn Meridian Adult 26-Inch 3-Wheel...
I need a replacement inter tube for the schwinn 12" roadster small (or backtire) wheel 54-152 (10x20. Where can I purchase
Feb 08, 2011 | Schwinn 12" Roadster Tricycle
Replacement rear wheel of quinny buzz
You can buy tyres off ebay at about £9 each. inner tubes are very cheap on there as well. Check out local bike shop as they might be cheaper.
Jul 26, 2010 | Quinny Buzz Three Wheel Stroller
Need help replacing front hub
Here's the steps....getting some pics for you....hang on a minute or two.
Front Hub Removal & Installation To Remove:
  1. Remove steering knuckle.
  2. Using a suitable slap hammer, remove wheel hub assembly.
  3. Using a suitable bearing press, remove outer bearing, oil seal, outer bearing race and preload spacer.
  4. Remove inner oil seal, inner wheel bearing and inner bearing race.
NOTE: It is not necessary to remove dust cover (back plate).
To Install:
  1. Using a suitable bearing press, install bearing races in steering knuckle.
  2. Pack the bearings and hub area with lithium grease.
  3. Install inner bearing in steering knuckle.
  4. Lubricate lip of NEW inner seal and press seal into knuckle.
  5. Install preload spacer into bore.
  6. Install outer bearing into bore.
  7. Lubricate lip of NEW outer seal and press seal into knuckle.
  8. Using an appropriate tool, support inner wheel bearing and press wheel hub into knuckle with a force of 2500kg.
  9. Install NEW inner seal.
  10. Install knuckle assembly.
May 13, 2009 | 2004 Kia Rio
Cannot replace rope the
remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
Nov 20, 2008 | Poulan Pro 22" Self Propelled High Wheel...
Schwinn 420 Elliptical Trainer Logo
52 people viewed this question
Top Schwinn Exercise & Fitness Experts
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Bill Boyd
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
