Question about Arcade Raw Thrills Big Buck Hunter Pro Video
Big buck hunter pro screen reads disconnected
When I turn the machine on it just flashes an error message saying disconnected and won't allow you to do anything. Has this happened to anyone? And what should I do??
  • Amy E
    Amy E Sep 29, 2014
    Stephanie - were you able to fix this issue? If so, how? I have the same problem.
4 Suggested Answers
  • 5 Answers
SOURCE: when big buck hunter pro is turned on I'm getting
Reimage the hard drive by opening the DVD drive door and inserting the recovery disk, which is obtainable from a distributor such as Betson in the US. Close the DVD drive door and power the game off then on again. Follow any on-screen instructions as the software installs. If this procedure fails or the game still gives trouble, you may have a failing hard drive. You could attempt replacement yourself if you feel up to it, or alternatively send the entire computer unit to a distributor or specialist dealer for testing and possible repair as necessary.
Posted on Jul 30, 2010
SOURCE: When turning Buck Hunter Pro on i am getting an
probably need to reload the software using the restore disc
Posted on Jan 10, 2011
SOURCE: I have a big buck
Hi wgutzke,
I see that you are experiencing fading on the screen and sometimes resets itself on occasions as you mentioned in your post.
Have you tried checking for any lose connections on the machine that can possibly cause shortage in the power or possible ground to the machine, this can be the cause of a fading screen and a reset on an occassion.
Try disconencting every conenction and start conencting everything one by one from scratch then try the machine again if the issue will occur.
Also if possible try a different power outlet from where it is connected and also if you can use a surge protector instead of directly conencting the machine to a power outlet.
I hope that this will be of help.
Have a nice day,
mvincentc
Posted on May 26, 2011
Big Buck Hunter Safari Displays "Disconnect" and Dell Computer On/Off Button is Orange, Not Green?
i haven't used my machine in over a year and when I turned it on the first time it said disconnected. I don't know what to do. could someone help please?
Mar 09, 2013 | Toys
Big buck hunter pro loses power and turns back on while in use
can be the cpu getting hot you can open the top side and with compressed air remove the dust take out the memories an clean with cotton humidify in alcohol I think shoul fix your problem
Jan 01, 2013 | Arcade Raw Thrills Big Buck Hunter Pro...
Big buck hunter pro is not working on the tv, can hear the audio, but the video will not work
I too am having the same prob. returned the first one back to cabelas brought home a new plug and play, it lasted all of 22 mins before it started freezing. will never buy another one.
Dec 25, 2010 | JAKKS Pacific Big Buck Hunter Pro TV Plug...
I have the big buck hunter pro for my tv, ive tried to do the shootgun calibration from multiple tvs and stood as far back as possible and it still wont calibrate, the menu button will not work either
I'm having the same problem. I found that if I put the LED box on TOP of the TV, it will recognize the first target, but not the second or subsequent targets.
It looks to me like this will only work with a smaller TV. The angles seem too large on a big screen TV. I've contacted the manufacturer to see if my guess is right.
Dec 25, 2010 | Arcade Raw Thrills Big Buck Hunter Pro...
When turning Buck Hunter Pro on i am getting an error message error 0x01 Loading Linux - 2.6.12-bs thei text keeps repeating on the screen.
You most probably have a hard drive problem, corrupt software or less likely a motherboard problem. First step is to reimage the hard drive. You need an install disk to do this. If one isn't present you can obtain one from a distributor such as Betson in the US or Brent Electronic in the UK. After turning the machine on open the coin door and press the DVD button on the computer to open the DVD drive's door. Insert the disk and close the door. Turn the power off then back on again. The software will now install, and follow any instructions. If the game doesn't run properly you will need specialist help. I would suggest sending the core computer to a distributor or specialist dealer for testing and repair.
Jun 06, 2010 | Arcade Raw Thrills Big Buck Hunter Pro...
When big buck hunter pro is turned on I'm getting system boot failure. This has happened a few time over the last month. The last time it happed I turned game off and it booted up. This time it is not.
Mar 12, 2010 | Arcade Raw Thrills Big Buck Hunter Pro...
Computer turns on but screen displays "no signal"
I am an amusement arcade game technician. I have found that the Big Buck Hunter Pro arcade games that use DELL pc's are fine, but the ones that use the "generic" pc inside have a tendency to overheat, causing capacitors to fail on the motherboard. You need to replace the caps , or get another motherboard.
Jan 28, 2010 | Arcade Raw Thrills Big Buck Hunter Pro...
Arcade Raw Thrills Big Buck Hunter Pro Video Logo
189 people viewed this question
Top Arcade Toys Experts
ray gallant
Are you an Arcade Toy Expert? Answer questions, earn points and help others
