Question about Schwinn 420 Elliptical Trainer
Replace motor Sent small electronic motor by Schwinn, have cover off but can't get center gray wheel off to reach motor
2 Suggested Answers
SOURCE: I need a replacement inter
You might want to try these guys : http://www.scootercatalog.com/tubes.html
They sell a lot of the small tube sizes because they are used with the little electric scooters.
Posted on Feb 08, 2011
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
My schwinn stealth 1000 shows I have power but when I twist my throttle nothing happens?
Melted means overload, blown means a short, possible causes-bad connection on battery leads, motor brushes worn, shorted wiring in motor or bad bearing, brake dragging on wheel, motor controller going bad. Check it with wheels off the ground , try to isolate what is binding , causing overload on the motor.
Jun 03, 2015 | Schwinn Motorcycles
In sewing mode the motor turns but needle does not move. I have checked bobbin & upper thread - any help?
1. Try to turn the hand wheel. Does the needle move?
2. Make sure the center wheel on the hand crank is tight.
Try the hand wheel now. If you still don't have luck try this.
3. Loosen the center wheel on the hand wheel. There is a small screw on the center wheel on the front or side. Loosen it until it almost comes out.
4. Now tighten the center wheel. (clockwise) Does the needle move if you move the hand wheel? If it does you can tighten the small screw.
5. If this doesn't do the job you will have to take the cover to the motor off. The motor has a bolt to loosen. As you loosen the bolt you can move the motor until it tightens the belt and makes it aligned as well. Run the motor slowly with the foot pedal and adjust the motor until it operates at it's highest speed. Now tighten. Replace all covers.
6. The belt is sometimes in need of replacing but not usual. You will know when you take the panel off.
Apr 16, 2015 | Sewing Machines
Where can i order a 26 inch rim for my schwinn meridian tricycle, since it's badly wobbling from 6 broken spokes?
I just put my Maridian together and two days later hit a small pothole on the left rear doing about 15mph so I called Schwinn and they replaced the wheel with no hassle. They have mnfg standards and a lifetime warranty...
Apr 24, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Attaching the seat to a schwinn locura bike
Posts could be different sizes. Should be able to just replace it with a longer bolt if in fact it is just not reaching.
Oct 01, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
I need a replacement inter tube for the schwinn 12" roadster small (or backtire) wheel 54-152 (10x20. Where can I purchase
Feb 08, 2011 | Schwinn 12" Roadster Tricycle
In putting together my 26"
Loosen both nuts on front wheel.
Stand bike straight up, or set bike upside down on seat and handlebars.
With fingers on fork and thumb on wheel, pull wheel so it is centered on fork.
Now tighten one nut part way. Keep holding wheel.
You may need somebody to help.
Then tighten other nut.
Go back to fist nut and tighten a bit more.
Repeat back and forth tightening until nuts are tight and wheel is in center of fork.
Dec 25, 2010 | Schwinn Men's 26" Jaguar Cruiser Bike
Where to find rear wheel bearing on meridian adult trike joe
Not sure exactly what you mean.
The wheel bearings are located in the hub, center of the wheel.
if you need to replace a bearing, then any bike shop should have them for you or they can order them up.
Dec 19, 2010 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Need to replace the drive belt on my Schwinn 430 Elliptical
http://download.dfxi.com/supportdocs/SM/Schwinn/SCH_430_431_450_SM_RevC_web.pdf
Follow this link for step by step instructions. Note you will need a crank puller which you can purchase at most bike shops. remove both covers then crank weldment(discs).
Jan 19, 2009 | Schwinn 430 Elliptical Trainer
Schwinn 420 Elliptical Trainer Logo
23 people viewed this question
Top Schwinn Exercise & Fitness Experts
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Bill Boyd
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
