Question about Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737
I have a Master Temp Pentair mod. 400 BTU/HR (ASME 460775 and a few months ago in the display shows error E05 and turn of, can you gime me a sugestions what to replace or to fix?RegardsJorge
Year 2012, purchased bran new
    Top Expert:
  • Pentair Master
  • 8,177 Answers
Shows ignition failure turn off then back on if same check ignitor and gas
Posted on Sep 29, 2017
4 Suggested Answers
  • 31 Answers
SOURCE: I have a Pentair 40,000 BTU pool and spa heater.
The heater is trying to light but cannot. Either the igniter is broken or you are not getting any gas to the igniter. Check to make sure your gas valves are on.
Posted on Apr 18, 2011
  • 910 Answers
SOURCE: Pentair Master Temp 400 E05
If you've already changed the thermal regulator then the only other thing it could be is the flue/flame sensor.
It could be just a loose or bad connection so I'd check them first before replacing it.
If you've got a meter then you could disconnect the sensor and check its continuity (should be 3-4M Ohms). If its OK then check the continuity of the wiring between the sensor and board.
Posted on Jun 12, 2011
SOURCE: master temp 400 with E05 error message, already replaced stack flue sensor, thermistor, and igniter. Any suggestions?
I have had the same problem with my '400' since it was new. I contacted the manufacturer and got the run around. I have been trying to get this resolved and now, a year and a half later, have decided to buy a different heater. Anyone want to buy a hardly used Pentair 400? sandtrap699@yahoo.com
Posted on Sep 23, 2013
When turning on power display reads 128 then error code r 13, after this it say's spa on but the temp reads 126 and the water temp is only about 68 so the heater never comes on.
This is not an error code. 128 r13 is the normal programming or software version for your model. you need to press the spa on button again, make sure the temp set point is higher then the actual water temperature
Mar 07, 2016 | Pentair Master Temp 400K BTU Natural Gas...
I turn on the heater and get error code R=9 and then shuts off....what do I do?
R9 is not an error code, but a software revision code.
Here is what you should do.
Take off the front panel underneath the circuit board.
Turn the heater on, if it doesn't Fire and gives no error code you need to look at the back of he circuit board and see what red lights are on. If you find one on there will be letters next to it to point you in the right direction of the issue. Example h1 or h2 would mean high limit 1 or 2.
If you don't have space to look by taking off the front panel only then you would have to take all panels off and get the top loose so you can lift it carefully to access the back of the circuit board.
Once you've done this let me know what you find and I may be able to further assist
Jan 15, 2015 | Pentair Master Temp 400K BTU Natural Gas...
Clean corroded thermastat
What is a thermostat plunger?
If anything is corroded, Thermister or Temp Sensor, just replace them.
Nov 15, 2014 | Pentair Master Temp 400K BTU Natural Gas...
Master temp 400 with E05 error message, already replaced stack flue sensor, thermistor, and igniter. Any suggestions?
I have the same exact problem with this unit. Obviously getting gas to the unit, because it runs and pumps out some serious heat for a short time, but then kicks off. Did anyone ever figure this out or did you buy a new heater? :-)
Feb 25, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
Pentair 400 2 yrs old won't heat spa to 98 degrees F.
This could be a number of things. Most often it will be the internal by-pass. You find the assembly inside the water header, it controls water flow through the heater. When it goes bad it can open at a low temp and keep the water from going through the heater.
Also you will want to check the temp probe on the side of the header. If this is bad it will usually show up on the temp display though.
Nov 18, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737 Logo
147 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
