Question about KitchenAid 32685 Mixer
Kitchenaid mixer wont slow down
I cannot change the speed of the mixer
SOURCE: KitchenAid K5SS mixer speeds up beyond set speed.
I have the same mixer and I believe your problem is the governor that is on the back of the motor. You can figure it out by downloading the repair manual here:http://store.mendingshed.com/kitaidparts.html The manual has all the info you need; including a troubleshooting section. The governor is availible from the the same site here:http://store.mendingshed.com/kagovernor.html What tipped me off on my K5SS was looking at the governor as it ran and I could see it moving back and forth; not steady like it should. Good luck!
Posted on Aug 19, 2007
SOURCE: Kitchenaid 250 watt. Speeds up and slows down on its own?
Call the Kitchenaid service number (1-800-541-6390 in the U.S.). As your unit is still under warranty, and they are very proactive I'm sure this problem will be readily resolved.
Posted on Mar 15, 2009
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
  • 130 Answers
SOURCE: Kitchenaid K45SSWH Mixer only starts fast then sometime slows
You can try adjusting the speed control as shown in section 6 of the service manual:
http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Also remove and clean the brushes as shown in the same manual pg 8 fig. #30.
Posted on Apr 19, 2010
  • 118 Answers
SOURCE: Kitchenaid stand mixer runs only on slow speed
The Kiichenaid mixer has a centrifugal speed governor. I suspect your is stuck. It will need to be disassembled, and inspected.
Posted on Jul 06, 2012
Kitchen aid mixer only goes 1 speed
The number in your question (9706529) is for the worm gear.
What is the model Kitchenaid mixer you have?
Jul 21, 2014 | KitchenAid 9706529 Stand Mixer Worm Gear...
Kitchenaid mixer K45SS only has one speed, slow. Have taken apart and regreased the machine. I plugged it in while the planetary head was off and it went through the speeds as normal, but as soon as
Did you clean the are around the variable-speed control lever?
Please be sure to unplug the mixer BEFORE disassembling the mixer.
http://www.ereplacementparts.com/kitchenaid-k45sswh0-classic-stand-mixer-parts-c-114958_114959_115060.html?page=4
http://www.ereplacementparts.com/article/11983/How_to_Replace_the_Speed_Sensor_and_Control_Board_on_a_KitchenAid_Pro_6_Mixer.html
Jan 07, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid motor slows
If it slows down when mixing, it is most likely that the mixer is being asked to do more than it is capable of. If it slows down when nothing is in the bowl, then the motor/gears/lubrication needs looking after.
The Service Manual is at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Dec 15, 2013 | KitchenAid K45SS Classic Stand Mixer
Jun 28, 2012 | KitchenAid Food Mixers
At its lowest setting, our mixer spins at ever increasing speeds until it stops and then, will not work at any setting.
Your motor needs to be replaced. The speed setting should be able to be set from the start, and if it will not slow down or change speeds, the motor has been over-heated and will need to be replaced. The only quick fix for this is to bypass the speed setting, and change the brushes on the motor. If you do not know how to do this, ask a serviceman to change the brushes only. Brushes usually run about $30 to repair. Although, you will only have one speed.
Nov 16, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid KSM150 stir and slow speeds are running too fast why is this?I just got this machine, its brand new from ebay (america)
It sounds like the speed control plate is not correctly adjusted. If you take the back cover off of the mixer (it is held in place with a screw at the top) and try adjusting the screws on the back plate you may be able to get the mixer to slow down.
You will notice two screws at the top of the speed control plate:
4893809-mz0mnwb1nd52ertzwibinpxu-3-0.jpg If you turn the top screws one quarter turn, both equally then test the mixer it should adjust the speed. Please make sure not to over tighten or loosen these screws as it can damage the speed control plate! You should not have to mess with any wires attached to the speed control plate or the bottom screw.
If you need more information please see the service manual here: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
It will specifically go over how to trouble shoot the mixer and how to adjust the speed control plate.
Please let me know if you have any questions
-Colleen @Mending Shed
May 22, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Apr 11, 2010 | KitchenAid KP2671 Professional 6 Series...
Mar 01, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid 250 watts k4ss mixer
The repair manual says that the mixer can make this grinding sound at slow speed, like stir or 2. This is normal, especially until it warms up. This is the sound of the gears turning at slow speed.
Dec 13, 2007 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 32685 Mixer Logo
22 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
