Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
DISPLAY SHOWS CE CE - Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
No display at all after changing the board do to a ce code
make sure voltage going in if ok check transformer for voltage also check any fuses
Feb 03, 2014 | Hayward H-Series 200k BTU Millivolt Heater...
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
Dec 10, 2013 | Kenmore Freezers
Display panel shows CE
CE is a general communication error. If you do not see any other error codes on the unit Check wiring between Main Control Board and User Interface Board. Replace User Interface Board. If problem still exist, replace Main Control Board.
Sep 01, 2012 | Electrolux EW26SS65G Side by Side...
MY CASIO CE-3700 CASH REGISTER SAYS E33 WHEN IT IS TURNED ON. How do I correct
Hi Josie. E33 means you have not entered amount tendered.
turn key to REG
Press SUBTOTAL
An amount should show on the display. Note this amount.
Type the amount shown on the display with no decimal e.g if display shows 12.30, type 1230.
Press CASH
Drawer should open.
If you cannot clear the error (try the clear button C) or no amount shows when you press SUBTOTAL, it probably means the memory has become corrupted due to a flat or faulty battery.
If anyone needs more information, C-tech collective have the Casio CE-3700 manuals here:
http://the-checkout-tech.com/manuals/cashregisters/Casio1.php
May 24, 2012 | Casio Parts Cash Register PC Desktop
I have a 6.0 CE eliptical and the tension is not adjusting it seems to be stuck on very difficult
adjust the magnet, tigh the bolts with some wrench. test the magnet with the magnet from refrigerator for to see if is attracted or repeled , change it if necessary.
sincerely. God bless you
Apr 18, 2012 | Proform 6.0 CE Rear Drive Elliptical...
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
Code ce shows we have tried to reset and the code CE come up each time
"CE" Communications Error If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Nov 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How do I set the date and time for this calculator?
Press and hold the ClockDate Set button for three seconds until the display shows the date with the first digit blinking. Enter a two-digit month, a two-digit date, and a four-digit year, followed by the ClockDate Set button.
Press and release the ClockDate Set button. Press and hold it for three seconds until the display shows the time with the first digit blinking. Enter a four-digit time, press AM/PM as appropriate, then press the ClockDate Set button. Press CE/C to finish and return to calculation mode.
Oct 17, 2009 | Canon P23-DHIII Calculator
CASH REGISTER CASIO CE 3115 DISPLAY E 03 AND ALARM
This ino might help: Cleaning ERRORS: ______________________________
1.- Turn the Mode lock to OFF
2.- Press down the RECEIPT FEED button
3.- Turn the key to PROGRAM
4.- Lift up RECEIPT FEED button (FFFFFFFFFF)
appears on the display panel
5.- Press SUBTOTAL (wait for receipt to issue)
6.- Turn Mode Switch back to REG and use as Normal.
Also another bit goes like this:
RESET: _______________________________________
1.- Insert the OW key and turn to OFF
2.- Hold down the JOURNAL FEED button and turn the key to PROGRAM mode
3.- Release the JOURNAL FEED button. The display should shows "00000000".
4.- Turn the key to OFF
5.- Turn to REG1. The display shows "INIT" and "0.00"
6.- Press the number 10801 and then press SUBTOTAL. Initialisation is completed when the printer stops operation. The display shows: "_ 0.00"
Hope this helps in restting to factory settings................................sodeep
May 12, 2009 | Casio Parts Cash Register PC Desktop
Washer won't start. shows CE on the display
That is a communication error between the control and the motor board.
Could be a corrosive buildup on the ribbon connectors and/or a bad wire or loose wire.
You can unplug the machine and trace all wires to look for a pinched or loose wire.
Unplug and clean all wire connections.
If that does not work it will be a bad motor controller.
Mar 04, 2009 | Kenmore 24032\24036 Top Load Washer
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
16 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
