Question about Drills
Is a Shop Source 18v drill battery interchangeable with Craftsman?
Is there 2 type of battery chargers for ryobi one+ and lithium 18v one +
I just went through this with Porter Cable 18V but I can't say it is the same for Ryobi. On the PC, all 18V batteries are interchangable on the tools, but the charging needs are different. A dedicated NiCad charger can't shouldn't be used for liOn but the later chargers will work for either battery.
Ryobi offers an 18V upgrade:
RYOBI Tools
Jan 02, 2015 | Ryobi Drills
Battery and charger
You can get aftermarket 18V rechargeable batteries that may interchange with your Coleman battery and may even use the same 18V charger
May 11, 2013 | Coleman Cable Coleman 18 Volt Combo Drill...
Where can i buy a battery for mcculloh drill md7d0010
The charger for my McCulloch 18V drill (Model 7488) has these specs: 18V Adaptor
Input: 120VAC, 60 Hz
Output: 18VDC, 400 mA
Model: TEAD-48-180400U
I hope this info helps you source a charger from other outlets.
Fred
Jan 16, 2013 | McCulloch Md7d0010 - 18v Cordless Driver...
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Are the 1.5 amp (BL1815) and 3.0 amp (BL1830) interchangable?
i have both the hammer drill and impact driver and have been interchanging the batterys without any problems
Jan 15, 2011 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Need to replace 14.4 powe drill
I recommend replacing your drill and light with an 18V Ryobi "One+" Drill and light from from the home depot. It outperforms any battery powered drill I have ever used. You can also get it with lithium batteries that will last twice as long.
Jul 06, 2010 | Craftsman 14.4 volt Cordless Drill/Driver...
I have 3 sears 18v battery chargers and they have
re batery got a problem not the charger
Jan 20, 2010 | Drills
Is the battery for the worx 18v string trimmer interchangeable with the worx 18v power tools,ie,drill or saws?
All you have to do is check the sizes of the batteries. If they are the same size, by that I mean shape and dimension, there is no reason you cant use them on different equipment. ...Lee
Sep 14, 2009 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
I have a craftsmen 18 volt drill. Will it be hurt if I use a 19.
You should never provide more voltage to a tool or motor than what it is designed for. So, as a result, I would advise strongly against it. You have the chance of frying circuits and capacitors very easily by doing so.
On the flip side, using too low a voltage will also result in motor damage. Stick with an 18v battery for an 18v drill.
If you are happy with this answer, please rate this response on FixYa.
Mar 22, 2009 | Craftsman Drills
Drills Logo
65 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
