Question about NEC VT800 LCD Projector
Electrical or plastic smell
Lamp goes out
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
The lamp is defective ,the quality of lamp housing is not good
you need a standard quality lamp with housing
the new lamp with housing USD120
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Posted on Mar 03, 2014
Microwave does not "heat" and smells when turned on.
calling the company will be the best suggestion because if the smell is like burning plastic, it will be a problem electrically
Mar 21, 2016 | Microwave Ovens
Burnt plastic smell from fan
the lamp is defective ,the quality of lamp housing is not good
Have a good day!
Feb 14, 2014 | NEC VT800 LCD Projector
Thomson 50DSZ644. Just replaced the Lamp great picture but burned smell.. after few house it smelled verry bad..and i turned off. now when i turn on the tv the picture in middle is dark and still thi
should have unplugged it when you noticed the smell.
UNPLUG and remove and look at lamp you installed--is something in the housing where lamp goes melted? I hope you did not touch the face of the bulb with your hand or fingers.
What ever is wrong find it before trying to use set again.
Dec 22, 2012 | Thomson 50DSZ644 50" DLP Rear Projection...
How do I remove and replace the entire head lamp?
its pretty easy you take out the two bolts on the top i think they are 10mm heads on them, remove the push in clips across the front plastic fascia, if u break one they have them at parts house, and remove fascia. Gently but in a solid manner pull upward on lamp assembly. Almost like a little **** but be careful ur releasing a plastic retainer that goes into the fender , pull back light and unplug electrical harness. reverse procedure to install. may require a firm slap to front of assembly to reseat plastic retainer in fender
Dec 01, 2011 | 2006 Pontiac G6
When I replaved samsung hls6767w lamp with hosing with new lamp with hosing I noticed burning smell.I assumed it is new lamp buring smell. After 15 mnts when smell did not go I removed power and when...
Most of the time the female end of the connector comes right of a part called the ballast. Ballast's are replacable. Is the aluminum melted? I am not sure where to purchase the ballast. The female connectors is ussally atached to frame with screws or sometimes clips
May 27, 2011 | Samsung HL-S6767W DLP TV
Awful smell and taste to water boiled in a stainless steel kettl
I have the same problem. Noticed it was in two different pots. The comment number one must be correct because I only use VERY high alkaline water to boil my foods. I had a feeling it was my water. So interesting! I will clean it w white vinegar and see if the smell goes away. SAME weird chemical smell- turns your stomach.
May 25, 2010 | Kitchen Appliances - Others
Horrible burning smell from lamp
If you ordered it directly from sony then i would be concerned and contact the to have it replaced under warranty. If you did not get it directly from sony I would expect it is a rebuilt lamp or you purchased just the lamp part instead of the whole cartridge and installed it into the carttridge yourself. The lamp is designed to be replaced as a cartridge . The smell is probly a lamp that is burning the wires on the back side of the lamp because it is incorrectly inserted and the wires are touching the glass. Just a couple times i have seen a lamp that will smell slightly as the plastic and insulation heats up for the first time.But it only smells a little for like a day.
Oct 15, 2009 | Sony 50 in. HDTV Television
Smells like burning plastic
Probably the odor from the new lamp. It should disappear shortly.
Jul 16, 2009 | Televison & Video
I replaced the bulb on my Samsung DLP projection TV (HLT5075SX/XAA) but now there is a plastic burning smell. Does anybody know what it can be?
That is probely the smell of the new lamp. If the odor persist and gets worse then remove the lamp and inspect it and the inside of the tv.
Jul 08, 2009 | Televison & Video
NEC VT800 LCD Projector Logo
55 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
