Question about Sanyo 42 in. LCD TV
No pic, just sound
I was watching tv fine and the pic went out. It was as if the tv was turned off. I continued hearing the tv as normal and it went black. I would say we have had the tv over a year with no problems. We have a cable box, sound bar, & PS4 plugged into it. I checked all cords--made sure they were plugged in tightly--also unplugged them all. I checked the input too. Nothing I did worked to make the pic turn on. Any ideas on what the problem might be?
  • Erin Ward
    Erin Ward Feb 14, 2014
    I might add that the TV is a 39 inch HD LCD. We use the DirecTV remote to turn the TV on & change channels. We use the sound bar remote to change the volume & the TV won't come on till the sound bar is turned on.
  • 269 Answers
Hi, you have not specified if your tv is still conventional tb that uses crt, or lcd
Posted on Jun 25, 2017
SOURCE: Sanyo Plasma Tv Black screen
I had the same problem and Sanyo does not make parts for this model anymore. Luckily I had the extended warrantee so they reimbursed the full purchase price.
Weird that the poster above mine was able to get a part; I was told the part is no longer available.
Posted on Jun 16, 2008
  • 5568 Answers
SOURCE: White screen only on Sanyo DP26648
Your reported symptoms are odd in that most failures are related to the primary power supply but that takes down both audio and video.
The backlight is obviously working (white screen) but it is no longer receiving any video information and this points to a failure of the logic (or the output of the power supply that services logic) used to control pixels on the screen.  Some screens have the majority of the control ICs actually mounted on the LCD assembly and because of very close pin distances used on dense ICs, they are often not replaceable by hand since they were installed by robotics.
I would first suspect (and hope for) the logic voltage output of the power supply to be the culprit.
If any of you posters have had a repair done and received any kind of a detailed report (you should), would you be kind enough to post it back as a comment to this original message?
Posted on Jan 16, 2009
  • 71 Answers
SOURCE: Sanyo Vizon 42' Plasma TV has lost its picture after 2 years
the bulb of your tv is dead. replace it
Posted on Mar 08, 2009
  • 8457 Answers
SOURCE: We were watching TV and the TV just turned itself
Yes,unplug,replug the tv an hour later.The tv should reset itself back to factory setting and work.Not,than the tv power supply board have problems.That the board,where the power a/c coard plug into it.Tries websites like, to buy a refurbish power supply board for the replacement.
Posted on Oct 07, 2010
  • 1768 Answers
SOURCE: DP32649 It has been working fine and when I
1.Your LCD unit has a power supply issue in the primary side of the main board.
It will need to be serviced.
2.There are possibly a rectifier circuit and blown capacitors that need replacement. You may have a lcd controller that needs replacement as well.
3. Sears repair may be able to repair it for a fee or you can contact the manufacturer for a qualified tech in your area to repair the unit.
Posted on Nov 01, 2010
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
My tv when connected to a video pics and sound comes normal, but when tuned to a tv station no sound will come but pic is fine.
Make sure your SAP button is not turned on. This will give you a no audio condition when watching broadcasts thru the tuner. If this doesn't help then your tuner could be defective.
Mar 21, 2013 | Sharp Televison & Video
When the TV first went out there was no picture or sound so I replaced the bulb and had sound and pic for about 6 hrs total between 2 days of watching the TV. So I sent that bulb back and received an...
This tv have a board call the ballast board to help the projection lamp to ignite.U hear clicking noises mean the ballast board is dead,not doing it job igniting the projection lamp.
Jan 17, 2011 | Mitsubishi WD-57733 57" HDTV
No picture, but power light is on
Mar 13, 2008 | RCA 27F530T 27" TV
DELL 42 inch Plasma TV
I have a 42" LG LCD TV and just experienced this today. Watching cable, then the screen went to black, but audio continued. I pressed the guide button on my remote and pic came on with my guide menu. But then went to black again 10sec later and has remained that way for nearly an hour. Tried switching off both cable box and TV, disconnecting and reconnecting cables, but no luck. Finally unplugged mains, waited a minute, then turned back on. Everything seems normal now after the reboot. Phew.
Jan 17, 2008 | Sony KV-36XBR450 36" TV
Auto shut off
maybe it was on too long. or there is just something wrong inside of it.
Dec 31, 2007 | Sony FD Trinitron WEGA KV-30HS420 30" TV
No pic but sound :/
You are having a high voltage problem. Quite possibly in the horizontal deflection. I would check the horizontal output and regulator transistors.
Sep 27, 2007 | Toshiba 40H80 40" Rear Projection...
Sanyo  42 in. LCD TV Logo
60 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
