Ever time I push a button it beeps continusly. I know the code to reset it which is (p-mode) 55 [st/all] 01 [#/ns] the register wont let me put it into p-mode. please help
Check your Ram,
Posted on May 19, 2014
4 Suggested Answers
flexion1
  • 737 Answers
SOURCE: Casio 240 Cash Register: Error 01
The reason it went into error is due to someone turning the key to another mode without finishing the current transaction. Turn the key to each mode until you find the mode that doesn't give error 1. If that mode is X or Z, then press SUBTOTAL. If that mode is REG, then press SUBTOTAL to see the amount due, then type that amount and press CASH
Need a manual for a Casio 240CR? Try here:
http://the-checkout-tech.com/manuals/cashregisters/Casio1.php
Many others at http://the-checkout-tech.com
Posted on Mar 28, 2010
Saigua
  • 981 Answers
SOURCE: I have a purple wr
Go to a nice watch site Casio runs and read a bit. Oh, and the model number's on the back.
Posted on Jan 03, 2011
  • 1575 Answers
SOURCE: dell 8200 beeps 10 times monitor won't come on says power saving mode
Hi
Remove the sound card and blow the slot with dry air to rid off dust.
Examine it to make sure nothing's damaged and fix it again.
Checkout the RAM's.Probably remove them,wipe the slots off dust and fix them again.Make sure they're well seated on their slots.
Posted on Feb 05, 2012
When turning on our sharp XE-A42S cash register in REG mode it lets us enter in a price, but when we go to push the department key, it beeps and displays misoperation...
Firstly, press subtotal (ST) button. If a price appears, you are in a sale and it is waiting for you to finish (try another method like credit). If it gives an error or beep when you press ST button and the drawer does not open when pressing CA/AT/NS, you probably haven't signed on. Try signing on using a PIN number (see clerk sign on in your manual)
Jan 11, 2017 | Sharp XE-A42S Cash Register
Stop beeping hour?
According to the directions: Press B - bottom left button,to go into Alarm Mode. Press D - upper right button - to activate the alarm and press again to activate the Chime, which shows on bottom left as a bell. To activate these press D. To DEACTIVATE them press D again. Press B 3 times to return to Time Telling Mode. It took a few tries, but D and B are the keys to stopping that annoying chime!
Oct 18, 2013 | Armitron All Sport Digital watch
I dont know how to change the time on my decathlon geonaute watch
I nearly went crazy pushing buttons, but finally got the right combination. From the normal Time Display (as you would normally use the watch, no need to push any buttons) Push and Hold for a few seconds the Lap/Reset Button. The "Set" Mode will become active. Release the Lap/Reset button when Set appears in the Display. Notice in the Display a small Arrow that points to a button, either the ST/STP or Mode Button. (Initially it will be the ST/STP Button). When you depress the button to which the arrow points, the Field Flashing in the display will be set (For ST/STP) or Changed to the next Field (When the Arrow Points to the Mode Button). Simply toggle through the fields (using the Mode Button) and set (using the ST/STP Button) as needed. You will also be offered the ability to set the Month, Date, Day, 12/24 HR, and a M-D (It stands for Month - Date, in Europe it's more common to display as Date - Month). I did not change this field since by default on my watch it displayed M - D first. The setting cycle will be finished off when you have set the various fields by again pushing the Lap/Reset Button. Not related to setting the watch, but possibly useful, the Watch will completely reset if all the buttons are pushed at the same time, including pushing the Display Light (or in the case of this watch, the illumination used for the Display Characters). Hope this helps, it worked for me.
Nov 01, 2011 | Watches
Cannot set time on 45/7012
Hold the reset button (upper left button) until the seconds start to blink. To go to the hours, push the mode button (lower left button). To set the hour, push the ST/STP button (upper right button) to the desired hour. To go to the minutes, push the mode button again, set the minutes with ST/STP button. To go to the date, push the mode button, set with the ST/STP button. Once done, simply hit the reset button to complete. Hope this helps!
Mar 13, 2011 | Armitron Watches
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Jan 25, 2011 | Fossil Watches
Clio radio just beeps at me+wont accept code!
enter the radio code by pushing buttons 1,2,3,4 on the radio and then push button 6 to confirm the code
if code is 3756 you sohuld push button 1 for 3 times, button 2 for 7 times...and then button 6 for few seconds
May 13, 2009 | 2000 Renault 181
Changing the time on my wristwatch
For the Amritron 45/6975:
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash2_bing.gif, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
Mar 08, 2009 | Armitron Two Tone Sports Watch
WR30 Wristwatch
hello,if you have the little circle window on the left of your face,that will tell you if the alarm and chime are on.
to turn them off you must push and hold the lap/reset button and at the same time push the st./stop button:
1 time takes of the chime-hourly beep
2 times takes off the alarm tha you set
3x's puts the chime back and 4x's puts the alarm back on.
Jul 21, 2008 | Timex 1440 53591 Sports Quotient...
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
