Question about HP Compaq 6000 Pro Small Form Factor PC (NV503UT) C2Q Q94000 264G500DVDRWW7P64 SFF DT (NV503UTABA) PC Desktop
Ram memory switch caused red light
I switched out the 256 pc2100 memory, with 2x528 pc2700 and got the red light and no boot up. Replaced memory to original, and no boot up.
3 Suggested Answers
ndguy2481
  • 251 Answers
SOURCE: Installed a new memory now computer won't boot up.
u just bought the wrong type of memory take the chip out of ur pc to best buy or a good computer store to help u buy the correct memory
Posted on Nov 24, 2008
  • 4044 Answers
SOURCE: Can I replace the 256 meg PC2700 333mhz mem card
In short no, you can't use that ram in this computer. According to the specifications on the HP website you can use PC2700/PC2100/PC1600 up to 2gb maximum memory for the pc.
Posted on Mar 02, 2011
What is the maximum memory capacity for the MX6027 model ?
Hello Marc,
The maximum is 1 GB. Standard, it comes installed with 256 MB but you upgrade with additional 256 MB or 512 MB memory modules. The modules you are looking for are:
256 MB DDR (1 x 256 MB) SODIMM (PC2700) 2.5v SYNC
512 MB DDR (1 x 256 MB) SODIMM (PC2700) 2.5v SYNC
There are lots of places on the web to find decent prices for this memory. I have included a few below.
http://www.memorystock.com/memory/GatewayMX6027.html
http://www.pcmemorystore.com/Gateway-M_Series_Notebooks-MX6027-ram.htm
http://www.computermemoryoutlet.com/Gateway-M_Series_Notebooks-MX6030-memory.htm
This document includes instructions for replacing the memory. It's a simple straightforward process.
http://support.gateway.com/s/Mobile/Q106/Blade/8511418.pdf
Hope this helps.
Have a blessed day.
Thanks for using FixYa
Jul 29, 2011 | Gateway MX6027 Notebook
I need L4000-H memory 512 or 256 how much????
go to crucial.com and check the "upgrade" for it http://www.crucial.com/store/listparts.aspx?model=L4000H%20Series&Cat=RAM
notebook.gif Your L4000H Series System SpecsSystem specs as shipped by the manufacturer.
Scan your system to view your specific system configuration. Memory:DDR PC2700 icon_detail.gif
Memory Type: DDR PC2700, DDR (non-ECC)
Maximum Memory: 640 or 768MB
Slots: 1
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot.*
May 20, 2011 | Lifetime ASUS L4000H Replacement Laptop...
I have a Toshiba Satellite A10-S129. It was working with 256 MB (2 x 128 MB). I wanted to upgrade it to 512 MB (2 x 256 MB). I bought 2 new 256 Modules and when changed it and turned on screen has...
If you get several beeps then there is a video problem. The video card uses shared RAM (part of the main RAM) and if the RAM is faulty the laptop won't boot up.
You might have incompatible RAM, try to use the same make and speed RAM as the original.
One of the RAM modules may be faulty.
Try installing one 256Mb RAM module then boot up the Toshiba, if it works the try the other RAM module.
Mar 20, 2011 | Toshiba Satellite A10-S129 Notebook
Can I replace the 256 meg PC2700 333mhz mem card with a 256 meg PC3200U 400mhz mem card?
Yes, you should be able to, however, if the memory bus does not support the 400 mhz speed, it will downclock to 333.
Mar 02, 2011 | HP Compaq Presario S4000V (P8655P#ABA) PC...
I have an emachine T5026. Emachine tech swears this machine only supports pc2700 ram but the stickers on the factory installed ram says pc3200 256mb x 2 so i bought 2 memory masters pc3200 1gb x 2 sticks....
PC3200 is backwards compatible with PC2700. Meaning you can install PC3200 into your motherboard but it won't run any faster than would PC2700, however it will not cause any harm and should work fine.
Emachine's would say you need PC2700 most likely because they're trying to sell you some.
One of your new memory modules or the memory slots on your computer may be defective. I recommend installing a single stick of memory and booting your system. If it is successful then shut it down, disconnect the power and install another stick. Boot again and keep doing so and by process of elimination identify the bad memory stick or the bad memory slot.
This is the "likely" cause and isn't too uncommon.
Good luck.
Sep 07, 2010 | E-Machines eMachines Desktop PC
I am working on my friends k7s5a Pro Mobo...
If you wish, tell us the socket number and we can then look up your board specifications. My guess is that the board runs pc2700 chips as the max speed possible.pc 3200 is faster(400MHZ)    than pc2700(333MHZ).
Mar 19, 2009 | EliteGroup K7S5A Pro Motherboard
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
RAM compatibility with MK79G motherboard
Hi, I am assuming that the original piece of memory was a 256mb ddr pc2700/333mhz ?
i have looked at your board on the product maker website and it supports memory to 2gb of pc2100,pc2700/pc3200 type memory. Be certain however that the new piece added is the same clock speed as the original that you are trying to use with it. You cannot mix clock speeds, either pc will not boot or it will only recognise the compatible piece. Have you tried booting with just the new piece 9 leaving out the older piece)if yes what was the result. Need more help ?? compdoctor2005@btinternet.com
Jan 03, 2009 | AOpen MK79G-N (91.8B110.101) Motherboard
HP Compaq 6000 Pro Small Form Factor PC (NV503UT)  C2Q Q94000 264G500DVDRWW7P64 SFF DT (NV503UTABA) PC Desktop Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
