Question about Seiko Instruments Smart Label 410 Printer
SLP 410 prints half the label
Windows 7
Computer wiped due to virus. Printer moves label, but no printing on it. NewWindows 7 Pro is the OP system. Any ideas?
did you install a windows 7 driver for printer. which windows 7 is it 32 bit or 64 bit version ? maybe print driver does not match 32 bit or 64 bit ?
Mar 13, 2016 | Seiko Smart 440 Thermal Label Printer
Slp 200 windows 7
Seiko has really downgraded its legacy product support and it has minimized its application and driver software available for download. To find software for your SLP 200 you'll have to good to a third party site like Drivers Guide. The link below is for version 7.0.3
Seiko SLP 420 Free Driver Download
Important tips when finding and downloading application/ driver software from non-OEM sites
1. Never install any application from a non-OEM site that says it will scan your computer to determine what files you need. - search using the manufacturer name, model number, and current operating system on the computer you want to install the device on.
2. Only install the files you found. Never download any software suggested.
3. When installing the downloaded files, always select Custom Installation to make sure you only install the software you need. In this case only the application and driver files, nothing else ( no driver updating, security scanning, toolbar, etc. programs).
In the specific case of the Seiko Smart Label printer make sure your printer is not hooked up until the Seiko software tells you to.
Jun 23, 2014 | Seiko Smart Label 240 Thermal Printer
Need to instal slp 100 application to windows 8
I think you're out of luck. Seiko has really downgraded its legacy product support and it has minimized its application and driver software available for download. You can try using a Windows 7 package. To find software for your SLP 100 you'll have to go to a third party site like Drivers Guide. The link below is for version 7.0.3 while it says its for the SLP 420 it's actually compatible with several models
Dec 17, 2013 | Seiko Smart Label Printer 100 Thermal
Smart label 200 windows 7 driver
The official Seiko site is:
Software Driver Downloads
However, Seiko has deleted its legacy printer support so you will have to find your drivers on a third party site. I've included links to your drivers below:
SIISLP200 Drivers Download for Windows 7 8 XP Vista
Note: With Seiko Smart Label printers make sure your printer is not connected to your computer until the Seiko software tells you to.
Oct 02, 2013 | Seiko Smart Label Printer 220 Thermal
Hi there I just got a new computer and try to copy the old smart label printer over, but when I try to print the label out, I got a message says.." SLP print manager can not start" What I...
when you say uyou copied the old printer over I assume you actually reinstalled the Printing Application from scratch?
You cannot just copy the seiko directry over, t doesnt load the .dll files
reinstall the application
biffo
Sep 08, 2011 | Seiko Smart 440 Thermal Label Printer
Every time I want to save a label I get "not valid slp label library." I have a Smart Label 200, use SL software version 7.0.0.412, on a Win 7 Home Premier, Dell 8800 SPS machine.
First of all I want to know this problem is occurred first time? If
yes then uninstall the software and restart your machine. Then install
again. Hope so your problem will be solved. Otherwise you should
download Smart Label v7.0.3.418 and try to install the new one.
Thanks.
Aug 21, 2011 | Office Equipment & Supplies
I have a Seiko Instuments Smart Label Printer 220. I have upgraded my computer to Windows 7 and I am runnng MS Office 10. Since upgrading I cannot get my smart label printer to work. I can get it to...
this is a problem that only the Manufacturer can solve for you . old devices do not like new operating systems or the other way around .possibly your only option is a new printer
Sep 21, 2017 | Seiko Instruments Smart Label 410 Printer
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
Seiko Instruments Smart Label 410 Printer Logo
77 people viewed this question
Top Seiko Instruments Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Seiko Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
