After the OS Winxp has installed some of its files, it needs to restart to continue installing or to setup the installed files. As soon as the system diagnostics is over it should boot up to the new hard drive... where the initial setup had taken place, but it seems that it just stops there, the cursor on the top left of the screen blinking it seems forever. It would boot on the CD but not on the Hard Disk after it restarts itself. I tried the hard disk to another computer and it worked perfectly. I had already changed my cables and even the power supply, well, it is still the same. So anyone can give me an SOS on this situation?
Comments:
Oct 30, 2007
- I did ma'am but all failed... I tried to use the hard disk to another computer and its funny from there it continued the unfinished setup. I'm beginning to think that the IDE controller chip is faulty... Ok I'll check it again... thanks... c ya later
Nov 16, 2007
- I had it already working... I cleaned the contact points of the DDR slot then placed the memory and the error is gone. Anyway thanks chrisking21for helping.
I purchased a Gateway DX4822-01 with an Acer GT43-AM V.2.0 motherboard. I am transferring everything...
(More)
I purchased a Gateway DX4822-01 with an Acer GT43-AM V.2.0 motherboard. I am transferring everything from the OEM case into a HTPC 8000 Media Center Case. I need to know the F-Panel pin configuration in order to hook up the power on, reset HDD led etc. I could really use the manual for the motherboard but Gateway is telling me they don't have it.
Hope you can help.
Thanks
I have a pixma mp830. I try to print in color but it comes out mostly pink with lines everywhere. I...
(More)
I have a pixma mp830. I try to print in color but it comes out mostly pink with lines everywhere. I have taken all ink cartridges and replaced them with new ones. I took out the holder for the cartridges and put it and warm warter none of these worked. Any suggestions?
