Question about Cisco Cp7942gch1 Unified Ip Phone 7942 With 1 Rtu License
When i go to my voicemail the prompter is speaking way to fast. it is not the playback but the prompter. how do i slow it down?
How do i slow down the prompter? i know to push the 4 and the 6 to slow down or speed up the voicemail playback. but this is the actual prompter asking you to push 1 for this and 2 for that. i cant understand what she saying. shes talking way to fast thank you
How to sdjust playback speed
That's what your owners manual is for.
Apr 06, 2014 | Audio Players & Recorders
My sony cfs-w360boombox plays tape at high speed upon play, normal or high speed poition
there may be 2 possibles
1, the pinch roller is not going down and staying in the fixed when during playback, easy way to check power down the unit, press play and see if it looks firm, it will push back, if working right
if its loose, it may well have come off a little sping, and may well be an easy ish fix, by someone who know about cassette decks,
2, the speed adjustment has failed, there will be an internal speed control, which keeps the playback at a correct speed, if this has failed it may be fixable, but only by someone who can take it to bits and remove and solder a new one in, and they are very small and Sony items i have had have failed on speed control! too for me its a junker box
good luck
Sep 24, 2013 | Sony Boom Box With CD Player & Cassette...
Recently purchased used Panasonic SL-HM42 turntable. Works, but turning a little slow on 33rpm (30-31rpms) says DC Servo System on the front. Don't see any set screws on bottom. would like to get platter...
How to tweak the playback speed on Panasonic SL-HM42 turntables
You will need:
  1. 1x small Philips screw driver
  2. 1x small flat-head screw driver
  3. An ear for correct pitch and a little bit of DIY skill!
Step 1 - Remove the wooden base plate
After ensuring that you've removed the the rubber turntable slip mat and securely docked the turntable arm, carefully flip the turntable over onto its lid to expose the wooden base plate, as per below.
Using the small Philips-head screw driver, remove the screws holding the wooden base plate in place, then gently lift the base plate off the turntable.
Step 2 - Expose the pitch adjustment screws
Once the wooden base plate is removed, you will see the speed-controller circuit board on the right-hand side.
To expose the the two speed/pitch-control screws, firstly remove the screw holding the speed-controller circuit board in place, then gently lift the circuit board up on the free side.
Step 3 - Correct the turntable playback speed and pitch
The easiest way I found to correct the playback speed was to flip the turntable carefully back into the original position, allowing the speed-controller circuit board to hang free as shown below.
Next, play a record that you know well and are able to tell when the speed/pitch is correct (assuming you have an ear for correct pitch, that is!), then at the same time using the small flat-head screwdriver, gently turn the speed adjustment screw(s) to adjust the playback speed up or down until the correct playback speed and pitch is achieved (or at least until it no longer annoys you ;).
Turning the screws clockwise (to the right) will increase the speed/pitch, and anticlockwise (to the left) will decrease the speed/pitch.
NB - Both screws allow for fine pitch control, so if the second is already at maximum speed, you can use the first screw for additional speed.
Step 4 - Reassemble the turntable again
When you're happy with the speed of your turntable, remove the record, the mat again & locking the turntable arm, replace the screw holding the speed-controller circuit in place (as per Step 2) and then finally replace the screws holding the wooden base plate, as per Step 1.
Happy listening!
Aug 29, 2013 | Audio Players & Recorders
Variation in speed of reels on playback
I would need to know what model you are talking about but could be bad- loose belt, lack of oil and relay contacts that control the motor speed being ressitive.
Dec 26, 2012 | Audio Players & Recorders
Voice mail playback speed is s...l...o...w... how do I reset it to normal playback?
The assumption is you are using Unity connections.
Complete these steps in order to change the speed:
  1. In Cisco Unity Connection Administration, find the user account or template that you want to edit. On the Edit menu, click Playback Message Settings. Set the Message Speed to Normal.
  2. If the users make any changes while they listen to voicemail, they are saved. In order to disable this, you can go to Advanced > Conversation > Save message playback Volume and Speed. Uncheck this to ensure that the changes made by users are not saved permanently.
If you are not an administrator, you can press 4 or 6 during the message to speed up and slow down.
Jan 05, 2011 | Cisco 7945G IP Phone
LG600G tracfone voicemail problems
My recently purchased LG600G (Target $30) immediately started receiving unwanted calls that forced me to figure out voicemail. Well, when I say "immediate", I mean once I struggled through the activation process! Turns out I wasn't pressing, and holding, one of the keys. The first of many firmware issues, read on.
Ironically, the phone is not by default setup to use the keypad for entering responses and I needed to enable DTMF tones. 9 Settings, 5 Call, 7 Send DTMF Tones. (btw, p.62 of the manual lists menu options 9.5.8 which is wrong). Select 1 then set.
I was then able to check my voicemail but my phone still doesn't actually let me hear the DTMF tones. I also have to hold the keys down longer than other phones; it doesn't like flying fingers.
Usually I check voicemail using a land line (or my wife's free work cell!). My local number is not my area code. For AT&T the requested mailbox is the cell number, followed by the 4-digit passcode.
Hope this helps somebody,
N
Jul 01, 2009 | Cell Phones
VX2100 record settings for slow motion playback when editing
you can't ! you have to slow you footage afterwards.
Anyway, try to record with a slow speed shutter (1/30th of a second or less) to fluidify your images but if you want to slow down your footage, it's probably because the scene is "fast" and this doesn't could help you anyway !!!
Dec 18, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Help! My Voice recorder is stuck in Slow playback/record
To switch back to normal press the PLAY button during
playback.
"Every time the PLAY button is pressed, the playback speed will switch."
Mar 31, 2008 | Olympus DS-40 Digital Voice Recorder
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Cisco Cp7942gch1 Unified Ip Phone 7942 With 1 Rtu License Logo
29 people viewed this question
Top Cisco Lands Phones Experts
David Burbee
David Burbee
Are you a Cisco Lands Phone Expert? Answer questions, earn points and help others
