Question about Konica Minolta Magicolor 4695MF All-In-One Laser Printer
Black marks on print copies
It looks like the scroll is leaving a deposit of black marks on the copies
  • Konica Minolta Master
  • 6,161 Answers
Replace the black image unit or fuser
Posted on Jan 18, 2016
BLACK MARK ON THE COPIES OR SCANNED IMAGE
Clean the slit glass under the document feeder. Lift the feeder and find the thin piece of glass on either the left or right side and give it a good cleaning - you marks will likely go away.
Here is a how-to for removing lines from Sharp copiers.
How To Remove Lines from copies prints on Sharp copier
Jan 17, 2014 | Sharp Mx-C402sc mx-C402sc
Sending fax error only
Can you post some images of exactly what this looks like? Just make a few copies of a blank sheet of paper if you need to - actually that would probably be better so we'd get nothing but the skid mark. I might be able to make some educated guesses about it once I see it.
Aug 21, 2007 | Brother IntelliFAX 4100 Laser Fax
LG fuzzy logic top loader leaves black marks on white. Happens when doing a large wash-eg; blanket -it looks awful. I'm thinking the insides might need cleaning? How is this done and with what product
If this is moldy looking you should use 1 cup of bleach in the drum with no clothes on the longest wash cycle with the hottest water. But I believe this is oil from the drive train and the seals on the bottom of the drum are going bad. When you wash something heavy like the blanket, it leaks.
Nov 25, 2013 | Washing Machines
HP 6050 leaving black marks of the back of prints
you need to print clean page two or three times to clean printer path for toner , then check the last page you if there other black market , tell me , what black market looks like , hope that helped you
Mohamed Hejazi
Afaqnama Libya
ipg@hplibya.com
Feb 25, 2013 | Office Equipment & Supplies
I'm getting black smudge marks on copies. After
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
Aug 11, 2009 | Samsung CLP 300 Laser Printer
Black marks on the entire page
If the marks look like brushstokes all over the page, then it most likely needs a drum GPR-6. Black marks can be caused by a dirty **** glass (the thin one) as well. the easyest way to tell is if the black lines are only on copies that went through the feeder and not on print jobs, faxes,or copies made off the glass then the **** glass needs cleaned.
Jul 29, 2009 | Canon imageRUNNER 2200
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
R1800 head streaks
I have been plagued by the same problem - the nozzles don't appear clogged - yet on heavier media there is a definite abrasive sound - and its leaving horizontal bands. After many cleanings with no luck I tried cleaning the heads with a bunch of Q-Tips lightly coated in Windex. After removing a ton of black deposits - it didn't immediately fix the problem; frustrated I turned the printer off. The next morning when the clean-heads-on-power-up kicked in - I noticed a large amount of ink collected in the vacuum sponge. It seams the bit of reside left over from the cleaning may have finally dissolved what I can only guess was a large ink deposit that had hardened and was striking the media when heavier stock was loaded. At any rate - no more abrasive sounds - and more importantly no more horizontal banding.
To clean I disconnected the power when the head was traveling. Then the head was free to move as I gently tried using the Q-Tips to clean the heads.
Hope this helps.
Dec 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Black marks on prints
Try a stand-alone copy, if issue still persists & warranty permits : contact manufacturer
Sep 07, 2008 | Epson Stylus DX4200 All-In-One InkJet...
Printing seperate account totals from copier
Press System/menu counter
Scroll down to User/Job accounting
Press Enter
Scroll down to job account set
Press Enter
Scroll down to Account Report
Press Enter
Select Yes
The Job accounting report is printed.
May 23, 2008 | Kyocera CS-2050 Black and White Copier
Konica Minolta Magicolor 4695MF All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
