Question about Bosch Drills
I am looking for the voltage of a bosch hammer drill gsh 10c
  • Bosch Master
  • 1,815 Answers
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
  • 3 Answers
SOURCE: my drill bit doesn't remain secure in the chuck of my drill.
grind bits shank in a triangle to let the drill chuck get a better hold of bit but be carfule because this also takes away the drills ability to slip if it hits something solid.
Posted on Apr 15, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
harlan301
  • 205 Answers
SOURCE: New bosch psb 550 re with hammer action. Hammer
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Posted on Oct 15, 2009
  • 211 Answers
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Posted on Dec 16, 2009
Bosch gsh 10c is not hammering
Likely the hammers are broken inside the drill.
Oct 07, 2016 | Bosch Drills
What's your problem? rotary hammer will not hammer
Look for a lever that has signs hammer/drill or just drill Place the lever in the hammer position.
Feb 19, 2012 | Bosch Drills
Good morning Sir, i fitted a complete service kit on my bosch gsh 11e but after a few moments of use it wouldn't hammer any longer, i immediately dismantled it but found nothing wrong. please note that i...
Bosch hammers work better under all environmental conditions with bosch grease part# 1615430010 or equivalent (such as hitachi, skill, or makita hammer grease). Bosch grease is light, slightly sticky with a high dropping point. If the grease is heavy and really stickey the hammering action will not be as desired and may get vacuum lock and not hit at all. Be sure to store hammer with nose pointing down to prevent hammer/anvel from slipping too far back into cylinder. In the case of Bosch hammers, more is not better. Too much grease has a negetive effect so just light application will go a long way. Good holidays
Dec 14, 2010 | Hammering
Broken Connecting rod in Bosch hummer GSH 11 E
you can go to Boschtools.com and download a parts breakdown for this tool with the explosion showing the assembly. Let me know if you need more assistance.
Jan 02, 2010 | Bosch Hammering
Solution for Armature winding technique used in demolition machin
Maybe contact people from this factory to become some technical information about your question Possibly more likely than Bosch try it. succes https://www.alibaba.com/product-detail/1614011072-armature-suitable-for-BAK-GSH_60330652111.html
May 05, 2017 | Bosch Sds - Max Demolition Hammer
The methode of changing brushes of gsh 11 e bosch
AT THE UNDER PART OF THE DRILL HAVE 4 LONG SCREWS TAKE THEM OUT AND U WILL SEE THEM.
Jul 10, 2009 | Bosch Sds - Max Demolition Hammer
Jan 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Drills Logo
183 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
