Chaintech 9, Serries 9EIL2
ZPC 9000
    Brigadier General:
  • 3,400 Answers
Where is the internal battery and what is the part number
Look in cybernet knowledgebase here for the solution:
http://www.cybernetman.com//kb/index.cfm/fuseaction/home.viewArticles/articleId/29
How do I replace the CMOS Battery in my ZPC? Cause - CMOS battery has gone bad
When replacing the CMOS battery in the ZPC, be sure the External Power Supply is unplugged and no accessories are plugged into the unit. Carefully remove the 5 bottom screws and the 2 screws on the back to remove the keytop. Once the unit is open, simply remove the bad battery and replace it with the new one. We use a standard 3V Lithium battery that can be found in most stores. When everything is put back together, be sure to press the CMOS reset switch on the side of the unit. Boot up the machine and repeatedly press the delete key to enter the CMOS Menu. Choose to Load Optimized Defaults, then press F10 to save and exit. The PC will now boot up normally
Jan 13, 2011 | Cybernet Systems ZPC-9000 PC Desktop
How do I replace the CMOS battery?
Make sure that the power should be off. Then open the CPU by using screw driver and remove the screw carefully and when the unit is once open then simply remove the previous "bad" battery that you wanted to replace it with the new one. "we use a 3v lithium battery as a standard" that are found in most "electronic" stores. After replacing or put back in your system be sure to press delete key repeatedly to enter the CMOS menu. There choose to load optimized defaults "e.g: date&time", then press F10 or choose save and exit.
There the PC should boot up normally. Hope it may be helpful to you
All the Best!
Oct 15, 2010 | Cybernet Systems ZPC-9000 PC Desktop
Cybernet Systems ZPC-9000 PC sound system is not working ++ have installed the window 7 and now no sound from the speakers but it show me it is working and my driver realtek up to dates ok even when i...
check all your connections are in properly and are powered on.
if all ok you might have to go back to your original os as not all driver devices are compatable with win 7.
hope this helps.
Jan 19, 2010 | Cybernet Systems ZPC-9000 PC Desktop
Have installed the window 7 and now no sound from
Hi friend,
You need to update your sound card because your sound drives is not working properly....you can installs your sound again from *********** board cd...
My zpc-9000 says it has 240mb of ram, is this possible? or am i having memory problems
No , this is possible , you really have 256MB but 16Mb is "Stolen" by the onboard video card for your display
If you found this solution helpful , please rate my solution below
Kind Regards
1234s282
Jul 01, 2009 | Cybernet Systems ZPC-9000 PC Desktop
Iwill zpc trouleshooting
Clean the CMOS by convert the battery on the mother board, Then try again
Aug 09, 2007 | Iwill ZPC (P4 ZPC) PC Desktop
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
