SOURCE: Watch band replacement
If you can, get yourself a small flathead screwdriver and grind or cut out the middle to resemble a barbecue fork. This will help you to hold down and move the springbar. If you can't grind or cut it, just use it to hold down the ledge that springs down (like a toilet paper holder) and push it over with that. It will probably take a few trials, because it is difficult without the right tools.
SOURCE: Pin that holds metal band clasp is missing
If it is only the pin that holds the metal band, this is an extremely inexpensive part that is available at most stores that sell watches.
SOURCE: replacing watch band on pathfinder pas410
Watchmakers use special tool to release spring bars, but it is possible to release them in home conditions. Place your watch on flat surface face down. Using pocket knife insert the blade between band and the watch lug where the spring bar (pin) end is and using lever action push spring bar end inwards. This should release the band from the watch. If all this does not work, then your watch band is attached with friction fitted pins and you will need watchmakers help, as without special pin removing tool it is not possible to remove friction fitted pins.
Rate me, plz.
SOURCE: BG1301 Casio watch replacement band
Go to "casio.com" and click on "support".
Although they don't say so directly, their repair section imply that they can replace straps.
SOURCE: Casio Fisherman (PAS400B) watch replacement clip for spring pins
mcdevito75 here, I'm surprised a jeweler couldn"t help. Here is Casio"s contact number, speak with them, TIP, get a spring bar 1/2 MM smaller and larger than what you measured. Contact Casio at 800-435-7732 9AM-----5 PM EST. hope this helps.
Please dont forget to vote if you liked my answer
thanks
