Reset lamp counter without OSD
The projector was of with red light "LAMP" i change the lamp, but not turn it on: red light "LAMP" i think must be reset counter but i can't go into the OSD, is possible with a combination of button in the pannel or remote control to make it?
    Problem Solver:
  • 23 Answers
Press the "help" button for 30 seconds
Posted on Feb 14, 2014
Testimonial: "sorry but there isn't help button is a dell 3400 mp"
I have an Sanyo PLC-SU07E Multimedia projector. I
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Aug 09, 2013 | Sanyo PLC SW20A Multimedia Projector
How to change lamp timer on sanyo plvz4
Hello
* Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items.
* Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button
8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Need to reset the lamp timer on a Sonya POA-LMP24 projector
Attach the power cord to the projector and plug it into an electrical outlet. Turn the projector on and allow it to initialize.
Press the "Menu" button on the top of the projector. Use the left and right arrow buttons to move the red box pointer to the "Settings" icon.
Use the up and down arrow buttons to move the red box pointer to the "Lamp Counter" icon. Press the "Select" button.
A pop-up window will appear displaying the number of hours accumulated on the lamp. Below where the hours are displayed is the option to reset the counter. Select the "Reset" option and then select "Yes" to confirm. This will reset the lamp hours counter to zero and reset the indicator light.
Feb 24, 2011 | Boxlight POALMP24 PART 9901 Projector...
I replaced the lamp in my Sharp xv-z90u. When I attach the power cord I get a solid green on the power indicator light. I also get a flashing green on the lamp indicator. I tried programming the reset...
First check your bulb properly matched with your projector. After changing the lamp reset the lamp hour (counting from 0hrs). Adjust the osd transparency.
If u set the lamp properly then It may cause the lamp circuit need repair.
Have you got yellow lamp indication before change the lamp? If occur then you have been late to change it. If you used it up to 2500hrs. then this problem may arise. Check those first if everything ok then may be the circuit have some problem, go to the nearest sharp authorize service center or visit website.
Feb 21, 2011 | Sharp Projector Lamp for XV-Z90U
How to change the bulb?
hi,
do the following steps to change the lamp of your projector.
1. Turn the power off and disconnect the projector from the wall socket.
2. Turn the projector over. Then loosen the screws and remove the lamp cover. If the lamp is hot, avoid burns by waiting for 45 minutes until the lamp has cooled.
3. Move the latch to another end as shown in the picture.
4. Loosen the screw that holds the lamp to the projector. If the screw is not loosened
completely, they could injure your fingers. It is strongly recommended that you use a
magnetic-head screwdriver.
5. Lift the handle so that it stands up. Use the handle to slowly pull the lamp out of the projector.
6. Insert a new lamp. Make sure the handle is fully locked, move the latch back, and
tighten the screw firmly.
7. Re-install the lamp cover and tighten the screw. Do not turn the power on with the lamp cover removed. Whenever the lamp is replaced, reset the total lamp operation time. Do not reset if the lamp is not replaced as this could cause damage.
8. Resetting the lamp counter
i. Press and hold the Exit 5 button on the projector for 5
seconds to display the total used lamp time.
ii. Press Auto on the projector or on the remote control to
reset the lamp hour to "0".
iii. Wait about 5 seconds to let the OSD disappear.
ok
Jan 19, 2011 | BenQ PB6110 Multimedia Projector
BENQ MP620C: We changed the bulb when old one was in 4000hours, but cannot reset the lamp timer? How to do this, because the projector turns itself off very quickly (we have maybe 30sec. time to...
I also had this problem but was able to get to the menu before it turned itself off..... Instructions in the manuel on how to reset the timer.
15. Resetting the lamp counter
damage.
projector for 5 seconds to display the total used
lamp time.
control to reset the lamp hour to "0".
Jan 01, 2011 | BenQ MP620 Multimedia Projector
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
Indicator lights on, no function, no fan, no lamp
Press the MENU button to display the "MAIN MENU", and then select "OPTION".
Press the ENTER button to display the "OPTION" menu, and then select "LAMP RUNTIME".
Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
Turn off the power and disconnect the power cord.
This will reset the cumulative usage time for the lamp unit to "0".
Oct 11, 2008 | Panasonic PT-LB20U Multimedia Projector
Reset the bulb
1-press the exit button on the projector for 3 second to display the total used lamp time.2-press menu button on the projector during the lamp hour message- an adjustement message will be appear press right or left arrow to reset timer to zero.if success osd change to(lamp hour reset ok!)
Jan 12, 2008 | LG RD-JT91 Multimedia Projector
77 people viewed this question
jasbo
jasbo
