Question about Riccar Vacuums
Blue light came on. Dont know what it means - Riccar Vacuums
    New Friend:
Only blue light I know of is the bright head lights
Posted on Jun 03, 2016
  • kasper galloway Jun 03, 2016
  • Riccar Master
  • 1,335 Answers
Depending on the model, it may mean it's time for a filter change.;
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Black decker problem
Sounds like it could be a bad battery pack that's not accepting a charge.
Jul 14, 2014 | Vacuums
Electrolux Unirapido not working green light flashes when start button is pressed!
I have the same problem with this type of vacum. I have tried a lot of things but the problem is with the software included in a 20 pins chip on the pcb so it can not be repaired. But, if you look in the back of the vacum there is a rubber stopper wich hides 2 pins. Maybe those pins can be used to reset the vacums pcb. I really dont know because in can't test it any more. I solved my vacum bypassing the vacum mainboard (pcb). Now my internal battery is directly connected to the 2 motors using a simple switch to powering on and off. The original pcb is conected only to the batery, recharghing wires and led wires so i can recharge the batery as usual. Sorry for my english, hope you understanded what i was trying to explain. good luck
Apr 15, 2013 | Vacuums
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
The blue light doesn't stay on. What do I do?
Hi Alec from VacuumSpot here. In Australia these are sold as the ergo rapido. The most likely culprit is the charger itself we sell loads of Electrolux Ergo Rapido Chargers basically the best bet is to measure the output of the charger to see if it is working properly (watch video) if it isnt then simply replace the charger. If it is then replace the vacuum handset - Electrolux have made the handsets real cheap so you dont have to do a repair on battery or motor.
Oct 26, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I have a 2 year old Electrolux ergorapido cleaner that gets used daily for about 2/3 min, the blue light on the stand comes on when the cleaner is put on to charge but fades after about 5 min & the...
No, not worn out batteries.
For my experience, if the batteries were worn, they would charge with the blue led being on and after that, the vacuum wouldn't hold his charge. just that.
This is a different problem. Check the contacts between the charging station and the vacuum, mines got bent a bit and stopped making contact. This has happened twice and just fixed it about 30 min ago. That is why the led first lights and then goes off, there was just a brief contact between them.
Nice vacuum, very powerful and handy but maybe it is just poorly made as it is engineered in Sweden but built in China.
Jan 21, 2011 | Electrolux Vacuums
How do I know if it is charging
On your stand there are blue lights that show when it is charging the vacuum. If plugged up with out the vacuum on the base the lights do not show. Once you set the Vacuum on the base the blue lights indicate that it is charging.
Dec 21, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Blue indicator light is not coming on. what i
I would take it back...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 19, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
