Question about Ridgid Ac1022 craftsman Router Table Band Saw Miter Gauge Hold Down Clamp
Ridgid ac1022 miter gauge hold down clamp - Ridgid Ac1022 craftsman Router Table Band Saw Miter Gauge Hold Down Clamp
2 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: where do I find the instruction manual for a Ridgid
You didn't mention a specific model, but hopefully your manual is listed here:
http://www.ridgid.com/Tools/Support/?warrantyMenu=%23&warrantyMenu=%23&criteria=LASER+MITER&selectType=Owners+Manual
Posted on Dec 17, 2009
What's best craftsman 10 miter saw?
More $$ generally = better quality, but not always. Many Craftsman tools today are very lightly built. Go to Home Depot and get a Ryobi or Ridgid saw, or Lowe's has Kobalt miter saws. All are at least as well made as Craftsman, and Ridgid comes with a lifetime warranty!
Oct 12, 2017 | Craftsman Saws
How do I make adjustments on my ridged r4512 table saw?
The carriage under the table is held to the underside of the table with several bolts or screws. Loosen those screws.
Raise the blade and clamp a stiff metal straight edge to the side of the blade. Use a carbide blade and clamp the straight edge to the sides of the teeth. Move the carriage around until the straight edge is parallel with the miter gauge slots, then tighten the bolts.
Oct 12, 2014 | Ridgid Saws
Where is the fuse located on my Ridgid miter saw?
Most AC voltage saws do not have a fuse. They usually have a built-in breaker or a resettable thermal overload. Look for a pushbutton near the motor.
Dec 05, 2013 | Ridgid 10inch Compound Miter Saw With...
Runs Rough
The noise you have is armature failure from bearing failure or shortening out from burnt/ worn brushes. It may be poling out from failed bearings/bushes or you have a short in one of the bars in the commutator bars. Have an appliance electrician check it out.
Jun 30, 2013 | Ridgid Saws
Miter saw laser adjustment for 12
Depending which model you have, the laser is part of the saw blade stabilizer and is not adjustable beyond removing debris between the stabilizer and the blade.
If the saw is not cutting square to the fence, that is a different adjustment. Rather set of adjustments. The procedure is outlined for your specific saw in it's respective owners manual. You can download here:
http://www.ridgid.com/Tools/Literature-Search You may need to enter the search criterria, but simply "Miter Saw" is adequate.
Feb 12, 2012 | Ridgid Saws
Where do I find the instruction manual for a Ridgid 10'' miter saw with laser guide?
Dec 17, 2009 | Ridgid Saws
My blade gaurd will not automatically rotate out of the way when lowering the blade to make a cut , Ridgid 12' compound miter saw
MS12502 has a solid arm actuation to move the blade guard, this is either bent, broken, unattached or otherwise not functional. sometimes the moving parts get full of sawdust and a major cleaning is all thats needed. generally all woodworking tools should be blown out with air after each use or end of day.
actual model number of your saw would be more helpful.
Dec 02, 2009 | Ridgid Reconditioned 12 In. Compound Miter...
How do i change the blade on a bosch 3912 chop saw
Push the saw down and manually hold the guard while it is the retracted position and let up on saw while holding guard,you should
be able to put in wrench and loosen bolt.
Apr 09, 2009 | Bosch 3912 12 Inch Compound Miter Saw,...
12 inch miter saw blade turns slowly and doesn't have any torque
There's no debris or wood jammed in the housing around the blade, is there? Try unplugging and removing the blade, to make sure some wood hasn't gotten wedged in there somewhere.
Otherwise, make sure the blade is on tight. If so, there is likely a problem with the motor itself.
If it's still under warranty, I'd contact Ridgid at this link: http://www.ridgid.com/Tools/Support/
Otherwise, they have a tools forum where you might be more likely to find someone who's experienced a similar problem.
Being reconditioned, it sounds suspect to me...
Sorry I couldn't be any more helpful...
Feb 21, 2009 | Ridgid Reconditioned 12 In. Compound Miter...
Ridgid Ac1022 craftsman Router Table Band Saw Miter Gauge Hold Down Clamp Logo
137 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
