Question about Bowflex Treadclimber
The treadles will not go up and down when treadclimber is turned on and I am standing on them.
The latch is in the appropriate position to use as treadclimber and not the treadmill mode as indicated in manual.
4 Suggested Answers
SOURCE: bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Posted on Jan 12, 2010
gascolator
SOURCE: I have bowflex treadclimber tc5000,
This is a common issue caused by a frequent assembly problem, made worse by the tools sent along with the TC for
assembly. To fix it, you need the following:
1. A GOOD 5/8" wrench (not the piece of junk that came with the TC).
2. A Phillips screwdriver at least 3" long.
3. Two books at least 1" thick.
4. One book about 3/8": thick, or two magazines
5. A vacuum cleaner with a hose.
6. The Treadclimber Manual. If you don't have it, get it online at the company's web-site.
Lock the treadles (see manual) such that the TC is just a treadmill.
Turn off the TC, unplug it, and remove the power cord.
Leaning the TC first left, then right, put the 1" books about 2/3 of the way towards the back under each side. This will left the rear of the machine slightly off the ground, making the following steps much easier.
Now use the Phillips screwdriver to remove three screws on each of the two rear-most plastic covers at the base of the machine. Remove the covers. Put the screws in the covers so you don't lose them. Note that the top screw is recessed deeply into a hole in the cover!
Removing the side covers has exposed 4 more Phillips screws that hold the back plastic cover in place. Remove them, and the cover will slip off (thanks to those two big books).
Everything is dusty dirty. Use the vacuum cleaner to clean it up. You'll thank me later when you don't sneeze your brains out.
Now, behind where the back plastic cover was, and across the back of the machine, are four big bolt-heads. These are the bolts that hold the tread assembly to the base of the machine. They're probably loose. If they're not loose already, use that wrench to loosen them a bit. Either way, things are out of whack.
Go around to the front of the machine. Use the small book or the magazines to wedge the right treadle away from the upright such that the treadles are evenly spaced between the two. Don't over-do it and reverse the problem! (This is a lot easier than yelling at your spouse or significant other to "hold it, hold it" while you complete the next step.) What you want is the two treadles nicely spaced between the front uprights. Trust me, the right treadle will hold that spacer.
Go back to the rear of the machine. Using the 5/8" wrench, tighten the four bolds VERY tight. Use some muscle. The fact that they were loose was the cause of the issue.
Now go to the front. Pull out the book/magazines that you were using as a spacer between the right treadle and the upright. Do the treadles look like they're now evenly spaced between the uprights? If so, pat yourself on the back. If not, then loosen the bolts and try again, adjusting the thickness of the front "spacer" as needed.
Put the rear cover back on. Don't over-do the tightness of the screws on this (or the other) cover(s)!
Put the left and right covers back on. Take care with these, they're a bit delicate, especially the top screws. If the little rubber posts fall out of the top screws, finesse them back in.
Don't forget to re-calibrate the machine (per that manual) after you finish.
You'll now discover in most cases that a lot of issues with uneven action are now cured. Any rub marks on the right upright can be removed with the same silicone spray that is recommended for the belts.
Enjoy.
Posted on Oct 25, 2010
ercupa190
  • 12223 Answers
SOURCE: Bowflex Treadclimber TC20 error messages
Dear Sir:
This is a common error in this kind of machine. You must call to the company bowflex, and claim the problem. The hardware design is defective, they will replace.
However you will the same problem, if you do not act right now.
God bless you
Posted on May 10, 2012
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
Treadles on tc5000 wobble and rub
You have to realign treadles ,take the back cover out and at the base of your unit you'll see two slides , couple of screws and yellow bushings if bushings are still in a good shape you can align treadles , if they're broken or worn out you have to replace them , I think there are 8 of them total ,they're called IGUS bushing
Good luck
Jan 05, 2014 | Bowflex Tc5000 Climber Treadclimber...
The treadles on my treadclimber are not rising and falling evenly. The treadle on the right seems ok, but the left treadle stays significantly lower. I have tried adjusting the dial to a lower number on...
Please RUN the software calibration for easy diagnostic and fix it.
go under the HOOD motor follow the steps, or read your owner manual /download from www. fitness.manualsonline.com
GOD BLESS YOU
Dec 02, 2013 | Bowflex Treadclimber
The right treadle is rubbing against the right upright why
please see the video and proceed according for fix it.
Please remember to LUBE the deck belt+roller bearing too.
God bless you
Feb 27, 2013 | Bowflex Treadclimber
My treadclimber is stuck on a high incline?
This is the nature of the treadclimber, the decks are inclined until you step on them. In use they should drop with your footfalls to absorb the impact, then rise back up as your foot nears the rear of each treadle. If you would like more travel as you walk turn the dials on the shocks to a higher setting, for less travel turn to a lower setting.
Sep 10, 2012 | Bowflex TC1000 Treadclimber
Dear Sir:
God bless you
May 09, 2012 | Bowflex TreadClimber TC20
Treadclimber centering
Dear Sir:
ecalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the TreadClimber by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 15, 2012 | Exercise & Fitness
Bowflex tc 1000 treadclimber
Jun 28, 2009 | Bowflex TC1000 Treadclimber
Bowflex treadclimber 5000
Napa 8300 silicone is recommended. Apply under belts from front to back one fluid spray and also in bearing areas. Squeaking can also be caused by the center of the treadles rubbing to hard. If this is the case they need to be adjusted.
May 29, 2009 | Bowflex Treadclimber TC5300
Bowflex Treadclimber rubs against housing.
Adjustment is needed. Remove rear covers and using a 9/16 wrench lossen the four bolts that secure treadle assembly to base. Place a 3/4 inch piece of plywood or a 3/8 inch socket extension in between the treadles in the front area. with that in place center them about an 1/8 in closer to the right upright as when you tighten the four bolt up the drive belt will place additional pressure and they should center perfect. tighten bolts...tight. remove wedge from between treadles and recalibrate unit. replace covers and enjoy. Use turtle wax on area rubbed to prevent rust.
Mar 05, 2009 | Bowflex Treadclimber TC5300
Bowflex Treadclimber Logo
112 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
