Question about DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale
Aws digital scales not measuring weights after i dropped them
Goes to 88888 no matter what. How do I fix that?
Are you over 330 pounds? If not, remove the batteries and count to 10 and replace them.
Description Item # 00835165000P Model # 4GNC25302 The GNC WirelessWeight GS-7006 Digital Bathroom Scale accurately measures weight, body fat, water hydration, bone and muscle mass. This item features a removable wireless display that can be conveniently mounted on the wall, so you can see the readout clearly. Built with durability in mind, the scale is made from extra-strong tempered safety glass. The GNC bathroom scale also features an energy-saving auto on/off function and auto zero.
  • Removable wireless wall mount readout display
  • Measures weight, body fat, water hydration, bone and muscle mass
  • Energy-saving auto on/off and auto zero
  • Extra-durable tempered safety glass
  • Weight capacity: up to 330 lbs
  • Requires one 9V and 2 AAA batteries (included)
Apr 28, 2016 | GNC Digital Bathroom Scale
How do i reset my digial bathroom scale
Remove all the batteries. In ones with memory, there are two sets, a 9 volt and 2 x AA.
Jul 16, 2015 | GNC Digital Bathroom Scale
I keep getting an err on my con air weight watchers bathroom scale, changed battery and it doesn't help
The unit checks itself when it comes on. This test is on the sensor that measures the weight. When it is out of calibration, the unit sends the error message, it is was dropped or over loaded it might need to be sent back. There are some other things that could be wrong but unfortunately there is nothing that an end user can do.
Jun 28, 2015 | Weight Watchers Health & Beauty
For seca 763 having problem with the display. All led segment was displayed and weight is varying.Kindly help.
Try weighing an inanimate object, is the weight stable? Maybe you're stabalizing yourself by holding on to something? That will throw it off. all weight must be on the base and not moving to get an accurate reading. If it's still unstable it need new weight sensors and calibration. Probably not a DIY.
May 06, 2015 | Seca 763 Electronic Weighing and Measuring...
I have a supreme weigh sw02 digital pocket scale i need to calibrate and need help
500ml 0f water is exactly 500g, measure that volume and put it in freezer bag and use as calibration weight, or if you have friend with scales - borrow from him scale weights.
if you use water - accuracy of the scale will not be absolute, it may vary few g either way.
another way - go to shop and buy 500g block of butter - put it on the scale in the shop - remove or add as you need till you have exact 500g, shop scales are accurate on that weight within 2g
do not forget to vote if you find this answer useful...
Jan 02, 2015 | Health & Beauty
Eat Smart scale showing body fat as much too low
Probably there's a build-up of skin oil from your feet that is preventing it from reading properly. Clean off the top of the scale with a cloth dampened in soapy water, then rinse wipe it with a cloth dampened in plain water, and dry it. Be careful not to dribble liquid into the scale.
Note: fat measurement by this method is difficult to do accurately and consistently, For best results, make sure you're properly hydrated at least ten minutes before measuring, and wash and dry the soles of your feet first.
Aug 05, 2017 | Eatsmart Products Precision GoFit Digital...
Propert Digital bathroom scales only reads half of body weight
If you want to measure accurate weight of your body, then you should to use Omron HN-286 Digital Slimline Bathroom Scale which uses 4 sensors for greater precision in order to accurately measure body weight.
Sep 04, 2013 | LG DVD 5095 DVD Player
SC-501 scale weight measures in Kilograms instead of centameters
Since centimeter is a measure of length, it would be difficult for any scale to measure weights in centimeters. It would be like asking a ruler to measure a length in kilograms.
Jul 25, 2013 | American Weigh Amw Sc-501 Digital Jewelry...
I just purchased a Healthometer Weight & Body Fat Monitoring Scale. I successfully setting up my scale, I think? When I turn the scale on and weight for the 0.0 to appear, I get on the scale and it...
These scales use sensors to measure the electrical resistance of the human body to calculate body fat. If you are not stepping on the scale barefoot then that might be the reason why it is timing out. These scales require you to step on it barefoot so it can take a measurement through your feet. And using the height and gender information in combonation with the resistance measurement it can calculate your approximate body fat precentage. If you are stepping on the scale barefoot then make sure that your feet are properly placed into the sensors and avoid any movement. Let me know if you have any questions.
Feb 06, 2010 | Health & Beauty
Digital scale question
Digital scales purport to measure your body fat through a process called BIA, or bioelectrical impedance analysis. Essentially, it clocks the speed that electricity travels through you. The scale runs a low-level electric current through your body, using your feet as positive and negative electrodes. The current encounters different levels of impedance, or resistance, from fat versus muscle. The scale measures this impedance, and throws it together with other factors (age, sex, height) to come up with your BMI, or body mass index.
Aug 27, 2008 | Detecto 253 Baby Scale Mechanical Infant...
DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale Logo
20 people viewed this question
Top DigiWeigh Measuring Tools & Sensors Experts
Tom Chichester
Bill Eager
Are you a DigiWeigh Measuring Tool and Sensor Expert? Answer questions, earn points and help others
