Question about Bowflex Treadclimber
Treadles won't go up and down
While turned on and standing on the treadles they will not go up and down. IT is like they are stuck. The latch is down as indicated in manual for treadclimbing not tread walking mode.
SOURCE: bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Posted on Jan 12, 2010
bwinton
  • 83 Answers
SOURCE: treadclimber tc3000 treads/STEPS WILL NOT GO UP & DOWN EVEN
Sounds like the hydraulic cylinders are bad. Try replacing them and should fix the problem.
Posted on Apr 29, 2010
gascolator
SOURCE: I have bowflex treadclimber tc5000,
This is a common issue caused by a frequent assembly problem, made worse by the tools sent along with the TC for
assembly. To fix it, you need the following:
1. A GOOD 5/8" wrench (not the piece of junk that came with the TC).
2. A Phillips screwdriver at least 3" long.
3. Two books at least 1" thick.
4. One book about 3/8": thick, or two magazines
5. A vacuum cleaner with a hose.
6. The Treadclimber Manual. If you don't have it, get it online at the company's web-site.
Lock the treadles (see manual) such that the TC is just a treadmill.
Turn off the TC, unplug it, and remove the power cord.
Leaning the TC first left, then right, put the 1" books about 2/3 of the way towards the back under each side. This will left the rear of the machine slightly off the ground, making the following steps much easier.
Now use the Phillips screwdriver to remove three screws on each of the two rear-most plastic covers at the base of the machine. Remove the covers. Put the screws in the covers so you don't lose them. Note that the top screw is recessed deeply into a hole in the cover!
Removing the side covers has exposed 4 more Phillips screws that hold the back plastic cover in place. Remove them, and the cover will slip off (thanks to those two big books).
Everything is dusty dirty. Use the vacuum cleaner to clean it up. You'll thank me later when you don't sneeze your brains out.
Now, behind where the back plastic cover was, and across the back of the machine, are four big bolt-heads. These are the bolts that hold the tread assembly to the base of the machine. They're probably loose. If they're not loose already, use that wrench to loosen them a bit. Either way, things are out of whack.
Go around to the front of the machine. Use the small book or the magazines to wedge the right treadle away from the upright such that the treadles are evenly spaced between the two. Don't over-do it and reverse the problem! (This is a lot easier than yelling at your spouse or significant other to "hold it, hold it" while you complete the next step.) What you want is the two treadles nicely spaced between the front uprights. Trust me, the right treadle will hold that spacer.
Go back to the rear of the machine. Using the 5/8" wrench, tighten the four bolds VERY tight. Use some muscle. The fact that they were loose was the cause of the issue.
Now go to the front. Pull out the book/magazines that you were using as a spacer between the right treadle and the upright. Do the treadles look like they're now evenly spaced between the uprights? If so, pat yourself on the back. If not, then loosen the bolts and try again, adjusting the thickness of the front "spacer" as needed.
Put the rear cover back on. Don't over-do the tightness of the screws on this (or the other) cover(s)!
Put the left and right covers back on. Take care with these, they're a bit delicate, especially the top screws. If the little rubber posts fall out of the top screws, finesse them back in.
Don't forget to re-calibrate the machine (per that manual) after you finish.
You'll now discover in most cases that a lot of issues with uneven action are now cured. Any rub marks on the right upright can be removed with the same silicone spray that is recommended for the belts.
Enjoy.
Posted on Oct 25, 2010
bugoy31
  • 1238 Answers
SOURCE: Assembled Bowflex Tread climber yesterday. Getting
Good day!
What is the model # of your Bowflex?
Posted on May 22, 2011
ercupa190
  • 12223 Answers
SOURCE: Bowflex Treadclimber TC20 error messages
Dear Sir:
This is a common error in this kind of machine. You must call to the company bowflex, and claim the problem. The hardware design is defective, they will replace.
However you will the same problem, if you do not act right now.
God bless you
Posted on May 10, 2012
How to thread a treadle machine bobbin? Minnesota Model A is probably from the 1920s.
You might try some of these sites:
Treadle sewing machine bobbin winding Google Search
They may not be your machine, but the basic elements should be similar.
Aug 14, 2016 | Sewing Machines
How do I find a Manual for Singer treadle Serial no. G1149496
Any sewing repair shop will have, or can get the leather treadle belts. They come in one size and you cut them to fit your machine.
Oct 03, 2014 | Sewing Machines
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
TC20 treadles will not move after we disconnected pistons and then moved unit when we tried to reconnect pistons one treadles is too far down to comnect and will not move
The treadles can sort of overlap and one gets stuck on the other. Try to carefully grab the front of the one that is higher and pull it away from the other treadle, then it should be able to be lowered. If you have a second person they could pull the lower treadle in the opposite direction. Be careful not to pinch your fingers!
Apr 26, 2014 | Office Equipment & Supplies
Treadclimber centering
Dear Sir:
ecalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the TreadClimber by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 15, 2012 | Exercise & Fitness
Storage bin under rear seat stuck
try pushing down first and holding it down while turning the latch. If it opens then spray it with some WD 40. If you can't push down hard enough then get one of you cute little curtain climbers to stand or even jump on it while you turn the knob. I hope i/m the winner. Picture me smiling with a big grin on my face. LOL I won I won. I helped someone. Keep me happy and let me know if I did. Good Luck, Raz
Apr 17, 2010 | 2004 Mercury Mountaineer
What does dE flashing on the LG intellowasher WD1050FHB mean?
It is an indication of door error. The door is either not shutting, locking or opening.
  1. Turn off the unit and unplug it for 5 minutes then replug and turn it on. If the problem persists, proceed below.
  2. Check the door latch
  3. Check if there is something that is caught in the door and prevent it to shut properly.Remove any stuck items that might push the door latch up or down during operation.
  4. Check if the door or gasket is damaged. Damaged door or gasket will prevent the door from latching or locking properly. Replace damaged gasket. Dis-aligned door prevents the door latch to lock properly.
  5. Check the door latch for any damage. Replace if defective.
Nov 04, 2009 | LG Washing Machines
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Olsmobile Silhouette latch stuck
Hi, my name is tommy.The easiest way to get the hood to open is have someone else stand outside the vehicle & push the hood down while you pull the release.It should release and when you get it open grease up the latch (wheel bearing grease works fine)and it should solve the problem.Hope i have been helpful.Have a good day.
Jan 18, 2009 | 1999 Ford Windstar
Bowflex Treadclimber Logo
203 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
