Question about Plumbing
Mira Sport 10.8kw all temperature setting lights are on. Low flow is off.
2 Suggested Answers
  • 42 Answers
SOURCE: Mira sport electric shower losing heat
It sounds like the heating element is going bad, needs replaced.
Posted on Dec 18, 2012
I have a Mira sport shower 'it was leaking water so I had to have it removed from bathroom wall,would it be possible led to have it repaired.
Absolutely... Scott Fullerton,
It appears to be a UK item...
My best recommendation would be to contact Kohler-Mira
by using the attached numbers and asking them for a local shower service RECOMMENDATION...
UK
Telephone: 0844 571 5000
www.mirashowers.co.uk E-mail: technical@mirashowers.com
Fax: 01242 282595
By Post: Mira Customer Services Dept, Cromwell Road,
Cheltenham, Gloucestershire, GL52 5EP
Eire
Telephone: 01 459 1344
E-mail: sales@modernplant.ie
Fax: Dublin 01 459 2329
By Post: Modern Plant Ltd (Dublin),
Otter House, Naas Road, Clondalkin, Dublin 22
© Kohler Mira Limited, February 2011
32
(www.mirashowers.co.uk)
OWNERS MANUAL (contact information)
Mira Sport Thermostatic 9 0 Installation User Manual Page 32
Hope this helps
Carnac the Magnificent Carnac the Magnificent
Nov 23, 2017 | Home
Dec 01, 2012 | Plumbing
Have a Mira Zest shower. Its about five year's old. Recently started to switch between extremely hot and very cold. Now only has cold.
I would suggest you google the Mira Zest and download the manual in PDFformat. From broosing it, it sounds like you had the temperature set too high, and that burnt out the element. But check the manual yourself and see if you agree.
But the Mira Zest is very susceptible to water pressure, so you might want to check into that also.
Jun 01, 2011 | Home
? faulty overheat function on shower
Check the in line filter in the inlet solenoid valve assembly. If there is crud collecting in the filter this will restrict water flow and the over heat protection will trigger to protect the heater elements
May 12, 2010 | Home
Mira Sport shower running luke warm
Your hot water must come from your coil in boiler and not from a seperate hot water heater - more then likely furnace hasn't been on for heating your house nor has it been on for any draw of hot water. You have to wait till it goes on and brings the water temperature up to your setting or get a hot water tank put in or a new type wall mounted gas instant hot water unit.
Mar 14, 2010 | Home
Temperature fluctuates while flow remains constant.(within the pump cut in/out settings) Max temp obtainable 43c
This sounds like a common problem with tankless type water heaters. The modulating burner has a set Btu range it can operate within, a maximum and minimum. With very low flow rates and very low temperature rises, the burner has trouble maintaining a steady output temperature because the btu load drops below the heater's minimum input. Typically the machine will overheat the water beyond it's setpoint, the burner will cut out, and then re-ignite once the output temperature has dropped low enough.
The solution to stopping this behavior is to simply increase the water flow through the device (i.e. higher flowing fixture or larger pump). This type of problem is exaserbated with recirculation systems that bring a very high water temperature to the unit.
Higher end tankless brands have a lower minimum input btu and thus fewer problems with this.
Aug 17, 2009 | Bosch Water Heaters
Does not stay hot long goes cold after 5 mins in my mira shower
This sounds like the elements or you just may need to turn the heat up. If it under two years old call the manu on the warranty. They make a good product so they should help you. I would check the heat setting first, though I doubt it is going to be the prob.
Jan 31, 2009 | Home
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
