Question about 1A Auto Parts 1983 Chevy C10 Truck 12 Tooth Power Window Motor
83 c10 truck 305cid 2wd blower motor does not blow
Replaced fan relay and all fuses seem to be good,can put direct power to blower and it will blow
    Sergeant:
  • 213 Answers
You will need to replace the relay under the hood in the fuse panel
Posted on Aug 17, 2014
Is there a fuse that run the air condition inthe honda odyssey 2006
Hondas all have a fuse and blower relay located in the battery junction block. You can try swapping relays around if the fuse is good. Then verify the blower motor is good by disconnecting it and applying 12v directly to the motor. If this checks good, check for 12v at the blower connector while disconnected, (key on/fan on). Had a CRV in the shop a few days ago with the exact same issue, power to the motor but a weak ground signal. Replaced the blower resistor.
Jun 13, 2014 | 2006 Honda Odyssey
1983 Chevrolet C10 Silverado: The AC compressor and heater blower motor fan will not come on.
The brown wire at the speed switch is the power wire. Powers is then directed to the blower motor resistor throught the orange, lt blue and yellows wires. The blower motor receives power through the orange wire. Check for power at the fuse with the key on. If there is no power the problem could be the ignition switch or the wiring in between the switch and the fuse block
Apr 05, 2013 | Cars & Trucks
Installed new blower motor. bearing shelled in old one. new motor won't blow. tested . it's good don't have power to moter. fuses good relay good. isthere a circuit breaker in wiring for b
I don't have a diagram for a 2008. On 2005 models the blower motor relay gets power from a 30amp fuse.
When the blower switch is in the high position the resistor is bypassed and power flows directly to the motor. The motor is grounded to the car.
The fan relay also gets power from a 7.5amp fuse and is controlled by the HVAC control on the dash.
Do you have power into and out of the relay?
Feb 25, 2013 | 2008 Mitsubishi Lancer
Interior blower fan relay 2002 overland
check heater/ac fuses first replace if bad..see if there is power to the blower motor connector if so reconnect and check ground wire for the motor.. if still no blow, take motor out and test for operation with 12 volt power supply(battery charger) replace if bad..good luck
Jan 16, 2013 | 2002 Jeep Grand Cherokee
2005 Ford Expedition heat/ac blower not working
I would start if you haven't already by checking the fuse. Below is a fuse layout diagram for your vehicle. The yellow arrow is pointing to the 40 amp fuse for the blower motor and the red arrow is pointing to the blower motor relay. If the fuse is good and having someone helping, while touching the relay with your finger have the other person turn the A/C fan on and see if you feel a click inside the relay. If you do not you may be dealing with a bad relay. You can also check to make sure you are getting power at the brown and yellow wire at the blower motor itself. Use a separate ground than the other wirw at the blower motor connector. You should have battery voltage there. If all is good so far you can put direct power and ground to the blower motor to see if it works and if it does you may be looking at the blow motor resister or the controller. I would need to know if you have a manual or automatic climate controlled system in prder to help further. This is all assuming you are talking about the front A/C system and not the rear or aux. A/C system. Hope this helps.....
May 07, 2012 | Ford Expedition Cars & Trucks
Heater blower not working
put 12 volt power to terminals on fan itself, if the fan works its the switch thats bad. or a fuse or relay ! if need be try and get another switch from same vehicle at junk yard. because the dealers are out to rob you. replace switch if motor and fuses are good. check the wires at motor to see if they are getting voltage. if not the switch is bad. sometimes if blower motor resistor is bad, fan will not blow on any speed. check this first. its beside the fan motor. if you need more info, just type in on computer. location of blower motor 2001 intrigue. good-day !
Dec 18, 2011 | 2001 Oldsmobile Intrigue
1997 Isuzu Rodeo V6 4X4. I have only owned this vehicle for 3wks and the fan/ac wont blow at all out the vents. The blue light comes on when i push the ac button but that is all it does. I don't know which...
C-19 Blower motor fuse 25A located in cabin fuse box. Left hand footwell on LHD vehicles, right hand dashboard on RHD vehicles.
Start by checking blower relay B-36 in the engine compartment fuse and relay box. Remove the relay. Jumper directly from battery to pins 85 and 86. (also see here: http://www.fixya.com/cars/r5544622-wire_relay if you dont know about relays) The relay should click Now measure across pins 30 and 87. Measurement should be 0 ohm.
Remove the blower motor(3 screws on the bottom of the unit under the passenger side dash) and connect jumper leads from the battery directly to the blower motor to see that it operates.
The blower motor resister is mounted on the ducting between the motor housing and the heating unit. Remove to test
Measure :
  • pin 1-2 : 2.4 ohm
  • pin 2-4 : 0.9 ohm
  • pin 2-6 : 0.28 ohm
  • pin 2-3 : 0 ohm
Aug 21, 2010 | 1997 Isuzu Rodeo
The fan does not blow. Both fuses are good [40 amp under hood & 20 amp under dash]. Heat does come through when driving but the motor does not blow. I have read to check the cable to the heater coil...
Normally, blower resistor for aircond car can be fuse blow. (Thermal fuse type). In my case, civic 1.7 ex 2002, i take out a part (DENSO 077800-0682) and open the black cover. inside there, have electronics board with some components. The Thermal fuse is paraller with Power FET. If you can't get the thermal fuse to change (checking using ohm meter to confirm it has cut off), just take a small wire and soldering between to leg of the thermal fuse. Then, try reassemble your blower resistor denso 077800 and try on your aircond.
Jan 08, 2010 | 2004 Honda Civic
No heat or air
Check the blower motor speed control resistor pack is ok.
(The resistor pack is usually located in the blower fan ducting in the air flow).
Check condition of electrical connection terminals on the blower motor circuit - these terminals pass considerable current and over time may fatigue overheat and loosen.
Check operation/replace any blower motor control relay,
Check the blower motor will run if +12v directly applied to the blower motor.
Check operation of the blower motor speed control switch is ok.
Oct 08, 2009 | 1993 Dodge Dakota
My a/c will not blow out air. You can feel the
Sounds like a blower motor not turning the blower. Could be elecrical. Check fuses that control the blower motor or blower motor relay. If these seem to be okay, locate the blower motor relay and try replacing it with a known working relay of the same style. If the A/C begins to blow, then you need a new relay. If not, you'll be looking into the blower motor or fan. Make sure your cooling fans function while your A/C is engaged.
Jul 03, 2009 | 2002 Buick LeSabre
1A Auto Parts 1983 Chevy C10 Truck 12 Tooth Power Window Motor Logo
142 people viewed this question
Top 1A Auto Parts Home Experts
Vernon Taylor
Robert Plante
Are you a 1A Auto Parts Home Expert? Answer questions, earn points and help others
