Question about Ricoh Office Equipment & Supplies
Scanner will not connect to any shared folder
Scanner will connect to any pc's
    Problem Solver:
  • 9 Answers
What is the model? What operating system is the server? It may need a firmware update.
Posted on Apr 29, 2014
How do i setup scanner from my machine to my laptop? please start from step 1 including cable connectios and scan to folder instructions. I am using windows 8.1 pro
Before you even start, your machines "Network Support" firmware needs to be up to date to be able to connect to a Windows 8.1 PC.
Secondly your machine has to be networked. No USB scanning supported on Ricoh Devices. Create a shared folder on your C: drive called "scans". Share so "everyone" can access the folder. On the MP2852 select scanner mode and tap the block with "Prg Dest" on the screen. Select Folder and Browse for your PC. Enter your PC Username and Password when asked. Find your shared "scans" folder, select it and then tap OK on the screen. Next enter your name and save. You should be good to go. Keep in mind anti-virus and firewalls can block it. Also ensure your PC is part of a "Home Group" otherwise you will not find your PC when you browse from the MP2852. If your PC is not in a "Home Group" then you can just create a "Home Group" under your "Network and Sharing Center" and while you are there ensure that "Password Protected Sharing" is switched off under your "Advanced Sharing Settings" also found in your "Network and Sharing Center".
May 28, 2016 | Ricoh Aficio Mp 2852 B&w Copier
Unable to access scan folder of Toshiba e-Studio 232 scanner from windows 7 system
Connect to copier/scanner using web browser. Click Administration tab, and logon use the copier's username/password. Click Network Click SMB Session Click SMB Session box In section called "SMB Signing of SMB Server", the default of "If client agrees, digital signature is done for communication" needs to be changed to "Digital signature isn't done for communication for the server" Click Set button at top, then Save button, and the copier will reset.
Nov 08, 2010 | Toshiba Office Equipment & Supplies
I cannot setup the scanning to file/server function
Remove the Server path entry.....
In your case server path (should be empty)
Jul 27, 2009 | Laser 3115cn All-In-One Printer
Copystar cs 305 scanner is not connecting to computer
I do not know much about the situation but, I'll give it a try. First turn the pwr off to the scanner and try to ping agian just to make sure you are not trying to use an ip adress that is aleady being used. You should not recieve a responce untill you turn the power back on but, if you do get a reponce while the scanner is off change the ip adress on the scanner. Next if that did not help, you will need a correct path to your computer from the scanner like example( \\server\public\scans ) next you will need a username and password to gain access to the shared folder..
Mar 30, 2009 | Copystar - CS-3035 Printer
Ricoh MP4000B
hi
a rijas working in dubai
my Gestetner MP 4000B nw its showing waste toner bottil is full please advice me how to solve dis problem
Feb 18, 2009 | Office Equipment & Supplies
SHARING SCANJET 5590
Go to the scanner folder, select the scanner >> right click >> properties >> Sharing
Asign a name on the network >> Ok
Oct 07, 2008 | HP Scanjet 5590 Flatbed Scanner
Too many connections win xp
In Windows XP Professional the maximum is 10, but you can set this to a lower value. You can use the Shared Folders snap-in to determine the maximum number of users that are permitted to access a folder. In the Shared Folders details pane, click the shared folder for which you want to determine the maximum number of concurrent users who can access the folder. On the Action menu, click Properties, displaying the Properties dialog box for the shared folder. The General tab shows you the user limit. Remember Win SP the maximus is 10. You can also use the Shared Folders snap-in to determine if the max numberof users that are permitted to access a folder has be reached.
Determine the number of connections to the share and the max connections allowed. If the max number of connections has already been made, the user cannot connect to the shared resource.
Jun 14, 2008 | Microsoft Windows XP Professional
13 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
