Question about Novatel Verizon Wireless Usb 551l 4g Lte Modem Aircard Usb551l Speeds Ships Fast
USB551L 4G LTE device not detected - Novatel Verizon Wireless Usb 551l 4g Lte Modem Aircard Usb551l Speeds Ships Fast
A verizon tablet. I don't find or see a model #
Search Results
    Verizon Ellipsis 8 4G LTE Tablet, Black 8-Inch 16GB
    www.amazon.com > ... > Mobile Broadband > Tablets
    Amazon.com, Inc.
    Rating: 2.3 - ‎46 reviews
    Ellipsis 8 Tablet 16GB, Wi-Fi + Verizon 4G LTE, 8in - BlackNetwork Type: CDMA .... After only one charge, I don't find either inferior to other android devices I've used. .... the worst mini tablet possible they would be well advised to model it after this ... Check out these pages to see more: verizon tablet, case eclipse 7, verizon ...
    Verizon Ellipsis 7 4G LTE Tablet, Black 7-Inch 8GB
    Amazon.com, Inc.
    Rating: 2.3 - ‎178 reviews
    See all Open-Box & Preowned offers from Amazon Warehouse Deals. ... Ellipsis 7Tablet 8GB, Wi-Fi + Verizon 4G LTE, 7in - BlackNetwork Type: CDMA ... Learn More; ASIN: B00GJ3MF9Q; Item model number: Ellipsis 7; Average ... it...guess they don'twant people to know the truth about their first foray into the tablet market.
    Verizon Ellipsis 8 Support ' Verizon Wireless
Jan 22, 2016 | Verizon Ellipsis 7 Tablet for Wireless
Activation
      Follow these instructions to activate your new or Certified Pre-Owned 4G LTE Android tablet.
      1. Step 1: Save Contacts and Content from Your Original Tablet. ...
      2. Step 2: Activate Your 4G LTE SIM Card or Transfer Your SIM Card. ...
      3. Step 3: Set Up Your New Tablet.
      Activating Your 4G LTE Android Tablet ' Verizon Wireless
      www.verizonwireless.com/.../how-to-activate-4g-android-t... Verizon Wireless
    Feedback
Jan 20, 2016 | Tablets & eReaders
Samsung s4 I deleted the apn on accident how can I get them back
Every carrier uses its own APN Settings to get its 3G/4G LTE network working on an Android smartphone or tablet device. Now, these APN settings are usually "downloaded" automatically to your phone when you insert a SIM card. BUT, there are times where the APN are not selected automatically OR when the APN settings are not downloaded.
In those instances, your 3G/4G LTE data will not work but that can easily be fixed.
Step 1. First, browse your Settings menu and find the "Access Point Names" menu. This is usually under "Mobile Network Settings" or "More Mobile Networks" or "Mobile Networks" under Settings menu depending on the Android device used.
Step 2. Once you are in the APN Settings menu, first thing you should check it that the APN is on the correct one. If the correct APN is not checked (sometimes this happens), simply check ON the correct APN for your carrier. That will make your 3G/4G LTE data working right away.
Step 3. There are also times where the wrong APN is listed or there's simply no APNs listed. In these rare cases, you can simply add a new APN, hit the "+" button. 25264381-evzu5111kn4ie1titkzzffdn-4-2.jpg
Step 4. For APN setting, the "Name" can be anything. "APN" setting is the most important, usually you only have to fill this out for your phone to work.
Step 6. Hit "Save" when done.
Step 7. Next, make sure to select the new APN Setting you have saved. Within 5-30 seconds, your phone should start picking up 3G or 4G LTE signals and your data should be working again on the phon 25264381-evzu5111kn4ie1titkzzffdn-4-14.jpg
Nov 01, 2014 | Cell Phones
I keep having to the was button to connect to the internet won't stay connecteded 2 my y800 WiFi device
Your Y800 device is a Wi-Fi router with a 4G connection on it.
It may be the 4G connection is intermittent, not the connection to the laptop.
You need to check with your mobile supplier that it supports LTE.
ALCATEL ONE TOUCH PRESENTS ITS LTE DEVICES FOR MOBILE CONNECTIVITY
Oct 15, 2014 | Computers & Internet
Activate a unlocked motorola 4G LTE from verison to boost
Eruck
Boost only allows certain serial numbers on their network. They don't let non Boost phones on network.
Mark
Motorola Support
Sep 19, 2014 | Motorola Mobility Verizon Wireless Droid...
Forgot my password to unlock lg verizon 4g lte
How to unlock LG Optimus 4G LTE by code ? Unlocking LG Optimus 4G LTE by code is very easy, it is also safest and non-invasive method of unlocking your phone. To get code for unlock LG Optimus 4G LTE You need to provide IMEI number of Your LG. Type on keyboard *#06# or remove battery from Your LG Optimus 4G LTE to check IMEI number. IMEI is written on the information labelas shown in this picture.
Do You want to unlock your LG ? To get unlock code for LG we need only IMEI number.
You will also need a sim card from the network that phone is currently working. Sim card will be needed when you enter unlock code to Your phone.
Codes for LG are from manufacturer database. Unlock codes are assigned to IMEI number.
If after enter to secret menu phone will ask for:
network lock - please enter NCK code
service provider lock - enter SPCK code.
Sep 02, 2014 | Cell Phones
Full instrouctions on how to flash sprint htc evo 4g lte to stright talk
You can't flash a CDMA phone(HTC EVO 4G LTE on Sprint(CDMA network) to a GSM network(Straight talk which is on T-Mobile's network(GSM network) the hardware is not interchangeable. A GSM SIM card is not the same as a 4G LTE SIM card(UUID) they store different data. GSM SIM hold your carrier account information that authorizes you to use the network while a UUID only hold data that is relevant to you accessing the 4G LTE part of the network the remainder of your carrier data is stored on the phone hardware.
Jul 24, 2014 | HTC Cell Phones
4G users
5 users may well be the limit to the number of users for this router. probably correct.
Apr 28, 2014 | Pantech Verizon Jetpack 4G LTE Mobile...
Free unlocking code for Playbook Lte (4g)?
There are no free unlock code available for Blackberry PlayBook LTE(4G) . But,You can get unlock code for cheap price from unBBlock.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code. They will give you the unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your Blackberry PlayBook LTE(4G).
Jun 18, 2013 | Cell Phones
Novatel Verizon Wireless Usb 551l 4g Lte Modem Aircard Usb551l Speeds Ships Fast Logo
97 people viewed this question
Top Novatel Computers & Internet Experts
ray gallant
Chris
Are you a Novatel Computer and Internet Expert? Answer questions, earn points and help others
