Formatting problems Recorded music plays for approximately 15 seconds before cutting out. Default message states "Format Error" Any ideas ?
    Sergeant:
  • 308 Answers
Older mp3 players cannot handle bitrates higher than 128 and you should not be recording them with variable rate either. I recomend, deleteting the card and start new with a standard bit rate
Posted on Feb 15, 2014
4 Suggested Answers
mixmaster
  • 626 Answers
SOURCE: message states unable to format
Make sure you dont have Rhapsody, or Windows Media Player open. Go to My Computer>Device Name (e260)>Right Click and select FORMAT. If that doesnt work, change the mode on the device Settings>Mode or USB Mode and repeat. Best of Luck.
Posted on Sep 30, 2007
SOURCE: yepo digital audio player
hi i can not transfer files to my yepo mp3 it says my comp dosnt support it i have windows vista loaded the manual says i must convert ACT to WAV format could you please tell me how to
thanks
Posted on Oct 05, 2008
SOURCE: Sylvania SMPK8854B MP3 Player File Format Error
hey, the way to do it is to install that little cd that came with it and save them to your desktop…now when you see them appear open the AVI converter…this will bring up a screen that asks to add the videos you want to convert and also a destination…just browse that and find your video that you want to convert and then make the destination the mp3 player and click convert…and whallaa! it will be ready to look at in your mp3 player…takes some playing with, but you’ll get it…God bless! <><
Posted on Jan 04, 2009
The memory card says unformatted card
Refer to your BR manual for procedure to format the card. Formatting the card in a PC just doesn't cut it.
Look in your index in the manual for "formatting" or "card"...etc.
Apr 13, 2010 | Boss Micro BR Digital Recorder
I have a 1gig Micro SD Card which is in a weird state.
well.. might b bcoz of virus.. jus do a hard reset and format ur card again n now fill ur stuff.. ( if u've mentioned ur mob model means it'll would be easyier to answer n i would've given u d reset codes.......) any how, for nokia *#7370# s d general reset code.....
Apr 08, 2010 | Cell Phones
Format Error
I hade just that prob. "format error" used to display. I did this:
1. dwl sonicStage (free)
2.- in the walkman went to menu/initialize/format
then displayed a confirmation screen, I confirmed
it displayed "formating...... COMPLETE"
3.- THEN plugged into the PC and transfered songs with Sonic
and it worked!
Jan 16, 2008 | Sony NW-E003F MP3 Player
Error message "failed to connect to player" "data blocked failed"
Don't buy an iPod...
I would recommend wiping and rebooting your player cos it's cheaper:
Windows only.... Please post if you are not using windows...
Open My Computer with your Rio plugged in.
Right click on your Rio player and click on format.
Leave the default values - if it asks you something then use your initiative.
Then click on format.
Then when it has finished formatting go to your firmware (can be downloaded from: http://www.digitalnetworksna.com/support/rio/product.asp?prodID=112).
Follow the instructions and then it should load the firmware onto your player.
When it has done then your player should (in theory!) work properly.
Hope this helps
Mowcius
Jan 08, 2008 | Rio Nitrus MP3 Player
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Cover art problem
The player doesn't accept removing of music, or formatting, when it is not done from SonicStage, the software that sony offers with it.
The software is to be downloaded here. When you've installed the software, format the player from the men. Then transfer your music with this program.
Nov 12, 2007 | Sony Network Walkman NW-E005 MP3 Player
Powering off after pressing RECORD button.
T.sonic cannot operate after it was formatted in Windows
Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the
default format of the T.sonic. To retrieve the default format, you must link to
http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
Aug 27, 2007 | Transcend T.sonic 610 MP3 Player
Sandisk sansa problem
This error message may largely be due to the corrupted Music Database file that the Sansa M240 creates to maintain an information pool on the music files downloaded to it. Normally, if you are unable to completely format the player in Windows Explorer, there are still 2 other (and actually, more recommended) options that you have: (1) Switching the M240 to MSC mode and formatting in "Disk Management". You can get to this window by right-clicking the "My Computer" icon and selecting "Manage". Make sure that you use the FAT file system to optimize the 1GB memory (2) Switching the M240 to MTP mode and formatting the player in Windows Media Player 10 or version 11. The mode of the M240 can be changed by accessing the menu and going to "Settings", then choosing "USB" In general, formatting the player in "Disk Management" is more effective than formatting it in Windows Explorer. Also, it would be a good idea to upgrade the player's firmware to the latest version via the SanDisk website: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 I hope this helps. The M240 is a great player.
Apr 20, 2007 | SanDisk Sansa m240 MP3 Player
How do I Change from default language back to English?
To reset the settings back to English:
1. Set the DM-20 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-20 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-20 for at least 3 seconds. The menu list is displayed.
4. Click the REWIND button six times to highlight the Format menu item.
5. Click the PLAY button to select the Format menu item. A message will be displayed with Cancel and Start options.
6. Click the REWIND button once to highlight Start.
7. Click the PLAY to select Start. A message stating that the data will be cleared will display briefly. Then a message asking if you are sure will be displayed.
8. Click the REWIND button once to highlight the Start menu item to continue with the format.
9. Click the PLAY select the Start menu item and begin the format. The format progress bar will appear. When it is complete the menu items will be in the English language.
Apr 07, 2007 | Olympus DM-20 Digital Voice Recorder
Very loud noise / Corrupt files on PNY Vibe
According to page 15 of the Vibe manual, "When formatting in Windows XP, if File System is FAT32 or NTFS, VIBE does not work." Step 2 under "Formatting VIBE" states: "After setting File system to FAT, press Start button to format." Don't know if this helps, but, if so, you might want to download the manual from support at pny.com. Sanddollar
Nov 19, 2006 | PNY Vibe MP3 Player
24 people viewed this question
 Grubhead
Grubhead
