Question about Breitling Watches
How do I set the time on my Breitling a68362 - Breitling Watches
Please MANUAL I need to set the time to BREITLING B1 (A68062). Thank you.
I am afraid apart from the aerospace you wont find most breitling manuals on line unless you find one on ebay with a watch box normally GBP50. I suggest you contact Breitling UK who will provide one at relatively low cost, they are very helpfull.
Jan 15, 2013 | Breitling Watches
How to set time on breitling aerospace
http://www.breitling.com/en/service/user-manuals/
press button till in time mode then pull out crown wheel and rotate slowly to adjust minutes or spin quickly to adjust an hour at a time.
If the digital and hands don't agree the process for correcting this is in the manual on the link above.
Nov 06, 2012 | Breitling Aerospace 455 Wrist Watch
I have a Breitling SuperOcean A17360. How does the rotating bezel work and how does one use it?
The bezel rotates (manuall) so that you can set the time you have to dive, next to the minute hand. Then as the minute hand rotates, you can see how long you have left before your oxygen runs out.
Mar 09, 2011 | Breitling NEW BREITLING AEROMARINE...
I've got a breitling superocean chrono and want to set the time, how do i do this?
Keep in mind that I dont have the watch in my hand... :-)
If this is an authentic Breitling...
You should have 2 buttons on the right with the crown between them. The crown screws down so you need to unscrew it before you attempt to set! Once unscrewed with gentle pressure pull the crown out. There should be 2 clicks, pull to 2nd click or furthest distance from case. That should be the time setting mode. Turn clockwise until the date changes then set your time. To change the date push back to the 1st click and that should be the date set mode. One direction will be for day and the opposite will be date. I believe that if you pull the crown back to 2nd click and push your buttons that should change the subdials for chrono. You might need to push both buttons at the same time.
Ive set Breitlings before but they arent a common watch we see. Most people dont use the Chrono so if the directions dont work for setting those then I wouldnt worry too much about it! Not many people are going to notice those. :-) Also be so very careful if its a real Breitling as they are a very expensive to fix! :-)
***DONT FORGET TO SCREW THE CROWN BACK DOWN OR YOU WILL GET WATER INSIDE THE WATCH!***
Jan 08, 2010 | Breitling Watches
How to set date on breitling watches
On most.  Turn the winding screw anti-clockwise until it clicks and pops out slightly. Pull it all the way out or half way out to change the time or date.
Sep 18, 2009 | Breitling A1336313 Bentley Gt Racing Watch
Watch setting
You could check for an owners manual at the link below or at least it's a starting point.
http://www.breitling.com/en/retailers/
Jul 27, 2009 | Breitling NEW BREITLING BENTLEY MOTORS...
Breitling Aerospace -setting T2
Here is a link for all settings:
vbr.com/docu/breitling4.htm
Sep 07, 2008 | Breitling Aerospace 455 Wrist Watch
Watches Logo
62 people viewed this question
Top Breitling Watches Experts
Shehu Pro
Shehu Pro
Ansel Alberto
Ansel Alberto
Are you a Breitling Watch Expert? Answer questions, earn points and help others
