Question about Prestige Remote Start
Starter isn't working
I have everything hooked up, minus the trunk and door lock features as they are already on my factory remote,but the starter still doesn't work. I had a shop tell me I need to purchase another module bypass. Is this true, or are they trying to sell me something?
  • David Harms
    David Harms Feb 14, 2014
    I have checked all the fuses and safety switches with volt meters. All are working as they should be, the system is getting power, but it just is not starting the vehicle. I have programmed and reprogrammed several times as well.
  • Audiovox Master
  • 625 Answers
Immobilizer Systems are common in most vehicles today. That's remote starters should be installed professional installers. What's the year, make and model of your vehicle?
Posted on Mar 03, 2014
Remote start locks doors but won't turn over engine, installed by dealer, two remotes do the same. Changed batteries in remote.where is the kill switch?
most remote starters have a valet feature to turn off the starter but allow locks/trunk to continue to work. all brands vary..
Jan 04, 2016 | 2013 Hyundai Santa Fe
Key won t unlock doors
If you have a remote you could use jumper cables to put power at the starter from under the car.
Feb 22, 2014 | Cars & Trucks
2003 fx35 door lock problems
The problem is the Door lock actuators and when I went to the dealer they want $467.90 to fix just my driver's side door, but after almost having a heart-attack from the dealer's estimate, I checked on ebay and found a Kit to fix the door lock for only $59 so i ordered one kit (shipping was super fast) it came with very easy instructions on how to install the kit, so I installed about 4-months ago in under 1HR and now everything is Back to normal, I can unlock/Lock using my original OEM key fob and also using the power switch on the door, so everything work as from factory ( no need for aftermarket alarm or remote) ... !!!! here is a link of the kit that I purchased. The seller is green-seller1975 and item #111291472359
Aug 21, 2012 | 2003 Infiniti FX35
I have 1999 Toyota Highlander with Pursuit Series Model 08SPr remote starter in it. I left the lights on battery ran out. I started car with jump. After that everything works except the remote start. I...
Check the hood pin switch. It's located under the hood around the edge of the engine compartment. It's designed to make contact with the hood when the hood is closed. Also, check for a remote start shutdown toggle switch under the dash.
Jul 20, 2011 | Car APS921 Remote Starter - Keyless Entry
I'm not really clear on how this remote start works. It seems as though I have to stop the remote start (cut car off) in order to unlock the doors. I have a separate keyless entry and having issues as to...
It is a common problem with factory remote keyless entry (RKE) systems when a remote start system is installed. Many RKEs will not operate when the ignition is powered as the case when engine is running under the control of the remote starter. There is no easy solution to get around this safety feature if you insist on using the factory remote to operate the door locks. The best option is to use the MARS-22 to control you door locks.
Jan 23, 2011 | Omega MARS-22 Remote Vehicle Starter with...
How do i wire in a alarm on my 97 suburban K1500 i need a wiring diagram to find wire colors for windows lights and etc........
1997 Chevrolet Suburban Car Alarm Wiring Instructions
Battery Constant 12v+ Positive Wire (+): Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Purple or Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Pink
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Pink/White Or White (This wire must be connected as ignition #2 for remote starting.)
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Orange
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Brown
Parking Light Positive Wire Location: At Headlight Switch Or In Drivers Kick Panel
Power Door Lock Negative Wire (-): Light Blue (Type A)
Power Door Lock Negative Wire Location: In Either Door Harness
Power Door Unlock Negative Wire (-): White (Type A)
Power Door Unlock Negative Wire Location: In Either Door Harness
Door Trigger Negative Wire (-): Purple
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: White (-), Requires Relay
Domelight Supervision Wire Location: At Headlight Switch
Trunk Release Negative Wire (-): Black (+) Or Black/White (Requires Relay)
Trunk Release Negative Wire Location: At Hatch Release Switch Or Low In Drivers Kick Panel
Horn Negative Wire (-): Black
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): White
Tachometer Wire Negative Wire Location: At ECM. The ECM (electronic control module) is located on the driver side inner fender.
Wait To Start Wire: When hooking up a remote starter on a diesel, you will need to program in the 5, 10 or 15 second wait to start timer in the installation manual. On some vehicles the wait to start light on the dash is not a true (+) positive or (-) negative and the wire from the remote starter will not work.
Wait To Start Location:
Brake Light Positive Wire (+): White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Mar 31, 2010 | Brand Remote Start/keyless/car Alarm Very...
Ive installed a Bulldog RS82 remote starter on a 2008 toyota camry. The remote starter works fine, the problem I'm having is that the keyless entry remote on the Toyota key does not unlock the doors after...
there is no solution to this, it is factory setup to prevent you from locking your keys in the car when it's running and so the trunk can not be opened by accident
Nov 16, 2009 | Vehicle Parts & Accessories
Dealer install remote starter bypasses kill switch
1) remote starter was not hooked up to the factory arm wire
2) trunk release was programmed to disarm factory alarm before popping trunk
3)parking light wire on remote starter was not hooked up
4)disarm wire from remote starter was not hooded up
5)this is not normal and they should fix the problem or have it done by some one else and have them pay for it, how much did they charge,
Bring it over I'll fix it right and not charge overpriced amount
Jan 11, 2009 | 2005 Hyundai Sonata
Remote starter does not work but will unlock and lock doors.
depending on your alarm which it sounds like a viper model maybe? on my 02 you have to incorporate a factory alarm bypass module in order to be able to start the truck, they run about 100.00 bucks and have to be profssionally installed. The truck wont start because the computer isnt recieving the proper starting sequence due to the factory alarm
Jan 11, 2009 | 2003 GMC Sierra 1500
Prestige Remote Start Logo
74 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
