Question about HP Officejet 5610 All-In-One InkJet Printer
Unable to FAx 5610v
I am unable to fax with the 5610v.  In the past I have successfully faxed.  However, recently I have been unable to fax manually, despite the fact that the fax pass the test when I press setup*6*6.
Any suggestions.
  • 1 more comment
  • Anonymous Jan 14, 2008
    cannot send a fax -can receive, but cannot fax out.
  • Anonymous Sep 10, 2008
    Can recieve faxes, but not send.
  • jdisimone Jan 10, 2009
    we are able to receive faxes from everywhere; but each time we try to send it fails, even sometimes it makes it one page in and then fails. please help. we have tried uninstalling the software and restarting the fax machine. nothing works.
My faxs reads phone off hook, all phones are fine
Posted on Jan 15, 2008
  • 30 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
745
Posted on Feb 27, 2009
SOURCE:
Unable to receive faxes. Can send
make sure there is no light burning next to manual or ans hook up!If there is one press the button till they all gone!
Mar 15, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
Jan 05, 2010 | Brother IntelliFax-2920 Fax
Cannot clear stored fax data?
look in the fax manual there should be a section on that
If you have no manual call the company where the fax machine was mad.
May 13, 2009 | Sharp AR-275 Copier
unable to send fax through power line carrier communication. only some part of the document received
Apr 28, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Unable to receive fax unless Westell modem is disconnected
sounds like you have a modem problem and that should the telephone company's call.
Jan 28, 2008 | HP Photosmart 2610 All-In-One InkJet...
IT will not print.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. OR A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. OR If faxes are present, you can transfer them to another fax machine. Go to Step 3. OR You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. OR To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 01, 2007 | Brother MFC-5840CN All-In-One InkJet...
Printer problem
MFC 5840cn - lcd shows 'unable to print see troubleshooting and routine'
Aug 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
211 people viewed this question
Clive
Clive
Thomas F. Schneider
