Question about Fish
How do u set temp
How do u set the temperature on Caravell wd60 open fronted chiller
Set the temperature
I can't get my temps to adjust
1 stay warm
1 stays cold
Jun 11, 2014 | Husky HUS-CN15 Wine Chiller
Caravell CATF61 can not find temperature control
It's supposed to go to -20! Is there a panel in the side at the bottom? Stat is inside the panel
Mar 31, 2014 | Caravell Freezers
Wine cooler does not stay cool
Do only if you are properly trained on live circuits.. Do at your own risk. Check the compressor's capacitor and the relay. Is the compressor getting juice?
Nov 23, 2013 | Avanti Refrigerators
Hi I have a Maytag model MFI2568aes my vegetables and fruit chillers are freezing everything. Chiller control is moved to the top which is cold, levers on chillers are far right. HELP. Gilbert cell...
Air is controlled by the damper located in the top portion of the refer section behind the ice maker assembly. Make sure the damper can open and close. If stuck open, this would allow air to enter all the time and cause freezing. Most likely the issue is found the the damper has failed to close when needed causing freezing. Double check the temperatures to the freezer, it can"t be any lower the -2 degrees, but you can raise it to 2 degrees to see if this corrects your temperature issue. The software was designed to bring in air from the freezer to produce ice first, then migrate to the refer section, if too cold for the freezer it would migrate into the refer causing freezing of veggies and produce.
I hope this information helps.
Nov 16, 2013 | Refrigerators
What is a good temperature to set my water chiller at for my plants
in general, the best water temperature for plants is 68 degrees F, (20 degrees C)
Jan 16, 2013 | Water Dispensing & Filtration
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Shows E1
    its because the thermistor in your refrigrator has failed . it controls the the temperature settings give me your model and brnd of your refrigrator i will give procedure to replace it
    Aug 20, 2009 | Caravell Refrigerators
    I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
    All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
    May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
    Fish Logo
    110 people viewed this question
    Top Fish Experts
    Richard Lindsey ...
    ThothMer
    ThothMer
    Level 1 Expert
    Tom Chichester
    Are you a Fish Expert? Answer questions, earn points and help others
