Question about Riccar 8650/8625 s Vacuum
No power N2000A - Riccar 8650/8625 s Vacuum
  • Riccar Master
  • 1,291 Answers
Check the cord first then the switch .
Posted on Jun 03, 2016
Power head does not work canister does . There is voltage at the power head.
Although it could be a multitude of things that keep the power nozzle from operating properly, the most likely is, since it's an Epic series, Is that the power nozzle elbow assembly needs replaced as the fine wires and top of the elbow tend to break/short after 5-10 yrs. of use.
It's also very well possible that the power nozzle reset switch or hose switch at top of handle is defective. Try plugging the power nozzle directly into the hose handle assembly and turn machine on. If the power nozzle still doesn't work, it's definitely a problem directly with the power nozzle.
Hope that helps!
Mick
Mar 14, 2015 | Electrolux Epic 6500 Vacuum
Power intermittent: when cable is touched power returns
You have a broken power cord. Hoover is notorious for power cords. I'm speaking from personal experience. Replace/have the power cord replaced.
May 08, 2012 | Vacuums
10 September 2011 I have a Denon clock radio in the kitchen, but it's not working. In fact, it hasn't worked in a long time. Help me. Serial # 71101100576
Hello there,
First you need to check if it is receiving power, try to connect the cord to another device to see if it will power it up. If it does, then it means the power cable is okay and does not need replacement, but if it does not power it up, then it means the power cord is bad and need to be replaced.
If the power cord works perfectly fine, check if the outlet is supplying current by plugging some other device to it to test if it is working.
If the power outlet is okay, then it means the problem is from the power board inside the unit of the denon clock radio. Have the power board checked for bad capacitors. If none found, replace the power board.
This time it should work.
Would be glad to know if this information was helpful to you. All the best Elect_Comp
Sep 10, 2011 | Vacuums
No power
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Aug 02, 2011 | Vacuums
No power to hose for power brush.
Does your power nozzle have an external power cable, (strapped on the outside of the hose) with a plug at the end where it connects to the Vacuum cleaner itself?
Or is the power conducted internally -- almost invisible, inside the hose?
If the former-- Usually the plug connections wear out-
Either way, you need to measure some voltages at the Power Nozzle itself---
Can you check with a volt meter, to see if voltage is getting to the Power Nozzle itself?
If so, look for a tripped Circuit breaker inside the power nozzle head-- or a broken wire?
Let me know what you have and what you find, and get back with me-
Mack B
May 02, 2011 | Electrolux Vacuums
Viewsat platinum not powering on
Regards....
Apr 17, 2011 | Vacuums
Powerbar will not come on
Take care.
Apr 01, 2011 | Dyson Vacuums
When I disconnect the power nozzle on my central vac I have no power for the accessory items
If there's power to the power nozzle, there's power going to the powered accessories, as well. The problem must be due to a defective/broken "item". It could be a loose wire, a switch, or the accessory motor. It needs to be replaced, or taken in to an authorized shop for repair.
Aug 14, 2010 | Electrolux Central Vacuum
I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
Dec 29, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
No power in power nozzle
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=493359
Posted by pjs5451 on Apr 06, 2008
Vacuumed with power nozzle one day working fine took attachment off to use crevice tool reattached power nozzle and no power whatsoever.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow Power Nozzle does have a reset button on the newer model on the top of the power nozzle, just push it and it should reset, or check all your pigtail connections to make sure they are connection and the cord leading to the actual Rainbow Vacuum itself. Out in left field might be that the power nozzle motor could be shorting out or not working or dead and might be in need of replacement. Check the cord for any frays or bad connections. If you have a problem please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
