Question about Panasonic DVD-CV52 DVD Player
Error code H01
Will not play or open. disconnected power to reset, but no change.
  • galatae Nov 26, 2007
    Did an idiotic thing and moved the DVD player without taking DVD's out. Now we're getting H01 error (alignment from the manual). Can I take this thing apart and fix it?
  • Anonymous Mar 27, 2014
    will not play vhs tape
I opened up by Panasonic dvd-cv52, which I purchased in Dec 2002 for H07.
The H07, based on research, indicated that the spindle motor had an issue, a post I found suggested trying some 3-in-1 oil.
I tried this and it worked (note, pop the top off firstm then power up the unit, then press the open button, then unplug the power, this will make it easier to lubricate).
Once I had done this and powere back up, I got h01.
Turns out I neglected to put back the elastic that is used to spin the carosel for the dvd's (I have a multi dvd player).
I would check to see if there is an elastic in place to spin the carosel, maybe your broke (assuming you have a multi carosel also)
Good Luck
Louie Whote
Posted on Dec 28, 2007
We took the cover off, found the errant DVD and screwed it back together. No more issues. Next time will take out DVD's before moving.
The error code H 01 in Shows my washing machine(panasonic na-f70gs)
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Apr 06, 2015 | Washing Machines
Hoover washer dryer error code h01
Its not an error it means its in delay start mode. Hold down the delay start button (looks like a clock) for 5 seconds and it should clear
Sep 12, 2012 | Hoover Washing Machines
Code 68 appearing on LCD screen off a brivis LPG ducted heater
This is a error that can be fixed with a specific reset sequence. Follow this process carefully. The unit will not turn on for long and turns itself off after about a second so you need to execute step 2 immediately after step one.
Step 1 - Turn on heater
Step 2 immediately press no 1 on the keypad - this will display the error code H01 #68
Step 3 Hold down no 4 for approx 5 secs till the screen goes blank
Step 4 The screen displays all of the settings and resets
Note: you may need to do this a few times before it works - wait some time before retrying. If a reset will fix the problem this is the solution - if it is hardware a service call is required.
Jul 18, 2011 | Heating & Cooling
Yamaha dvd s-80 showing error code H01 when trying to play disc. What does this mean ?
The manual isn't much help, is it?
It seems the "H01" is some kind of common and fatal error code in many disc players and I have yet to find anyone who has paid the ransom, er cost, to get one fixed as it is cheaper and makes more economical sense to just buy a new unit...
Feb 11, 2011 | Yamaha DVX-S80 System
What is error code 3802
"Printhead Failure" (error code 3802)
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Remove and install the printhead two times.
  4. Wait 30 seconds to allow the printer to reset.
  5. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  6. Close the printer access door.
If error condition continues, contact Kodak for printhead replacement.
Best of Luck
Nov 17, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I am trying to use a Panasonic AJ-D650, which hasn't been used for about 5 years. Initially the DVCpro tapes wouldn't load but they are now loading correctly. However if I press play or any other command...
most likely problem with the AJ-D650 is deteriorated electrolytic capacitors on the mechanism drive board. when these caps fail, the mechanism will not load completely, if at all. also check for bad capacitors in the signal path from the head drum. first and easiest step is to clean the heads; often a good cleaning will restore operation to a non-playing machine.
Oct 22, 2009 | Panasonic Televison & Video
Ricoh aficio 3045 error code sc 541
Here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad thermistor,bad fusing lamp or a bad connector.
Oct 02, 2009 | Ricoh Office Equipment & Supplies
H01 Error
H01 means that there is an alignment problem or there's a faulty lens mechanism. Align it would cost about $50 . If there is a faulty part , then cost would start from about $80 labour plus part.
Aug 08, 2009 | Panasonic DVD-RV32 DVD Player
Kenwood KDC-MP438U "USB ERROR"
Dec 20, 2008 | Kenwood KDC-MP228 CD Player
Error code H01
it means no head motor rotation...The full meaning is given as: After Cylinder lock is detected the cylinder does not start rotating again even after tape unloading.
The remedy/ check is given as: Check the cylinder motor drive circuit... sorry no solution but at least you know whats wrong..
Aug 07, 2008 | Panasonic NV-HD680 VCR
Panasonic DVD-CV52 DVD Player Logo
2,070 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
