Question about AT&T 5.8GHz Cordless Phone System with Digital Answering Machine
No power to AT&T digital answering phone
Plug power cord in ,but the phone has no power
Answering machine wont turn on
Have you checked and made sure all the proper cords are plugged in to the proper places? Also, have you tried just pushing all the cords further in, because the problem might just be that the cords aren't in correctly?.
Jan 16, 2014 | Panasonic DECT 6.0 Expandable Cordless...
Uniden phone cant answer
Unplug the phone from the 110-AC source for maybe 30 seconds, then plug-in to let it boot up again. FYI, your land line becomes useless with cordless phones when the 110-AC power goes out. Advice you keep an old-school corded phone handy nearby to plug into the RJ-11 phone jack as a backup when household power goes out. The RJ-11 wiring includes power, which provides voltage power to old-school corded telephones. You can procure old-school corded phones really cheap from your neighborhood thrift stores.
Nov 29, 2013 | Uniden Lands Phones
Red light flashing "line in use" and unable to receive calls
Suggest you visit their support website or find their 800 number. Or try disconnecting from the line & removing all batteries for a minute, then reinstalling the batteries and reconnecting to the line.
Nov 26, 2013 | AT&T DECT 6.0 Cordless Phone System with...
I lost the manual and need to get a new one for: AT&T 1856 corded speakerphone with digital answering system Thank you
AT&T Corded SpeakerphoneThe AT&T 1856 Corded Speakerphone with Digital Answering System offers the home-user peace of mind thanks to its power failure operation that doesn't require batteries. The Speakerphone features three one-touch memory buttons and a 9-number speed dial. The phone is caller ID and call waiting capable with a 50 name/number caller ID history, and features a visual message waiting and new call indicator. A large, LCD display with adjustable contrast controls allows for easy.
Apr 24, 2011 | AT&T Corded phone
Own a GE 29870GE1 telephone with digital answering machine. The digital part works but can't get a dial tone.
Try unplugging the phone from the wall power outlet plug it back after like 3 minutes. Power on and see if you get a dial tone, if not, try reset the unit, once the unit is reset, the problem should be fix. Follow this steps to reset the unit,
Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this will fix the problem.
Take care.
Sep 23, 2010 | GE 29897GE1 Corded Phone
No dial tone on any of the handsets which means answering machine doesn't work or caller ID or missed calls
is the main base plugged into the phone outlet? make sure it is and i would recommend putting a filter on the end of the cord. (dsl filter) then plug filter into wall. hopes this solves it! (note you might need to replace your phone cord).
Feb 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 | Music
Extream ststic
try a corded phone and unplug your cordless. see if that helps. If not go outside to your power meter and near it you should see a box labeled telephone. open it and you "should" see a spot to plug in a corded phone. you first have to unplug the little cord thats already in it then plug in you phone. If no static, then prob is in your house wiring or in a defective old jack or possibly another device plugged into your phone line (computer, answering machine, caller ID box, etc. ) .
If you do have static while outside & plugged into the "test jack" , then prob is in the phone companies regulated facilities and they will come out and fix no charge to you.
Jan 02, 2009 | Uniden Cordless Phone
How to connect the answering machine to my telephone
You should have two jacks on your answering machine. One should be marked "Line". Plug the telephone cord from your wall into this one. The other jack should be marked "Phone". You will need another telephone cord to plug into this and then connect the other end to the phone.
Nov 13, 2008 | GE 29888GE1 Digital Answering Machine
AT&T 5.8GHz Cordless Phone System with Digital Answering Machine Logo
20 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
