Question about Grilling
Model RJ-A propane regulator
No propane getting past the regulator. Can the regulator stick and not allow flow?
5 Suggested Answers
gcken
  • 140 Answers
SOURCE: Kenmore Gas Grill 141.155401 issue with Propane tanks
replace the regulator
Posted on Apr 14, 2009
  • 1335 Answers
SOURCE: have a 2 year old char broil bbq, have to start it
More than likely, the valve at the barbeque is clogged. Sometimes spiders will plug the valve since they are drawn to the smell of the propane. You can either clean the valve or replace it.
http://www.charbroil.com/consumer/ReplacementParts.aspx
Posted on Jul 28, 2009
  • 4736 Answers
SOURCE: I have a brand new
Julian, let's get this corrected for your 4th of July Cookout.
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first & turn it to HIGH.
Did the burner light and the fa,e height look correct? If so, light the remaining burner exactly
the same way. Now, do all the flame heights look correct? If so, you solved the problem.
Always remember to turn the tank valve ON Very, Very Slowly.
If the above didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly, as the regulator is locked up. You can pick one up from any home center or hardware store that sell grills and accessories for about $30.00. Take your old one with you for comparison purposes.
I hope this helped you troubleshoot and solve the problem, Please let me know and Happy Grilling!!
Posted on Jul 04, 2011
  • 4736 Answers
SOURCE: Unable to get gas our of 'Blue Rhino" propane
The problem is an easy fix. Replace the current Hose/Regulator Assembly with a new one. They run about $30.00, at home centers and hardware stores that sell grills and accessories.
Once you install the new one and connect it to the gas tank, open the gas tank valve Very Very Slowly (Slow Motion, Slow) until it's fully open. If you don't do it this, the new regulator will lockup.
Hope this helps you & thanks for choosing FixYa.
Posted on Aug 25, 2011
Hooked up proane tank used once then no flame on grill. There is propane in the tank but no propane flows out of it either when hooked up to the grill or when opening the valve directly on the tank. This...
The valve on the tank has an internal valve that will not allow you to release propane into the atmosphere. It must be connected to a regulator line in order to open.
It sounds like your regulator has failed. Remove the regulator assembly, inspect it carefully for blockage or hose kinks. If there none, try replacing the regulator assembly.
Gary
Sep 24, 2011 | Weber Genesis E-310 Gas Grill
I am not getting gas from the propane tank to the grill, I can hear it flow but then it stops
The common problem is the regulator...they go bad and will not allow the gas to flow...
heatman101
Aug 29, 2010 | Kitchen Ranges
I cannot get the gas grill to light. The tank was not completely empty but I replaced it anyway to make sure that was not the problem. I have the same problem with the refill. It does not seem to be...
the regulator could have gone into lock up.
try this to unlock it...
  1. Open the BBQ Lid
  2. Turn ALL main control knobs to the "OFF"/CLOSED position
  3. Turn the Propane tank valve to the "OFF"/CLOSED position
  4. Disconnect the Regulator hose from the Propane tank
  5. Turn ALL main control knobs to the "ON"/OPEN position
  6. Let stand for 1-2 minutes, allowing all excess gas in valves and manifold to dissipate
  7. Turn ALL control knob back to the "OFF"/CLOSED position
  8. Reconnect the regulator hose to the Propane tank- hand tighten only.
  9. Check all hose connections to ensure that a positive seal has been made
  10. SLOWLY turn "ON"/OPEN the propane gas supply
  11. Wait approximately 5 seconds for the regulator pressure to stabilize
  12. Turn "ON"/OPEN the selected burner control knob to "HI"
  13. Press the Multi Spark ignition button or match light selected burner.
  14. Hope this helps you has me in the past!
Jan 08, 2018 | Char-Broil 463220004 Grill
My q grill is not heating properly. I have a full tank of propane and the grill is clean but the burner is not getting enough gas to heat past 200 degrees
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 30, 2010 | Weber Q Grill
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Hot dog cart grill and steam tables/gas to grill freezes up
It isn't an unusual problem and most people who use pressurised gas experiences the problem sooner or later due to a sudden drop in pressure equaling a sudden drop in temperature.
Multiple cylinders might be the answer but an electrically heated manifold or gas line would be better.
Nov 19, 2017 | Kitchen Appliances - Others
Coleman propane stove problem
The connector for attaching the regulator to a disposable propane cylinder has a sintered bronze filter in the tip of the brass probe tube that is prone to clogging, or the bronze pellets get mashed down over time, restricting gas flow, and this will cause a portable grill or camp stove to perform poorly. The filter is so fine that it takes very good eyesight and bright light to see that it isn't solid metal, or use of a strong magnifying lens. The best solution is to buy a new Coleman regulator assembly. If you are unable to get a new regulator assembly and have the skills and the tools, you can try drilling a very small hole on the side of the probe tube with a #60 drill bit, just below the bronze filter, but near enough the end of the tube so that the hole will be past the plastic seal when the disposable cylinder is fully screwed into place. You should avoid drilling directly into the end of the probe tube, as the end of it is used to depress the Schrader valve in the disposable cylinder to allow gas to flow. A #60 wire gauge drill bit is only 0.040 inch (1.016 mm) in diameter, but makes a hole large enough to supply sufficient gas to a portable grill or a dual-burner camp stove. If you choose to perform this work, the probe should be unscrewed from the regulator body and the Schrader valve core in the probe tube should be removed before drilling. Be sure to clean all brass and bronze particles out of the probe tube before re-installing the Schrader valve core and the screwing the probe into the regulator. Use a removable-grade thread locking compound to secure the probe in the regulator body and don't over-tighten it, so as not to crush the rubber gasket. Allow the thread locking compound to cure for several hours before attempting to use the regulator. Keep in mind that this modification increases the likelihood of dirt getting into the needle valves and jets of your stove or grill, which can cause maintenance problems in the future.1_28_2013_4_49_27_pm.jpg
Aug 19, 2008 | Coleman Gas Grill Stove
Grilling Logo
442 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
