Question about Sylvania 6427FF TV
MisaLIGNMENT DOUBLE IMAGE
  • 21 Answers
Are the Double images different colours. If so, may need the convergance adjusted.
Posted on Feb 19, 2014
I have a mitsubishi model # WD73C9 television it is displaying vertical lines and double vision, what may be the problem?
double vision ( ghosting) sometimes indicates an antenna misalignment/ bad connections or reflection of the signal from something like a roof or building wall
Feb 15, 2016 | Mitsubishi WD Televison & Video
Sony KP51WS510 seven years old - have double image.
Ur tv have a problems known as a convergence problems,it is dead.The tv convergence board must be repair by replacing 2 STK convergence ICS and some or all of it resistors too.To fixed tv 3D or misalignments R,G,B colors lines tv picture.Are u willing to put in another like $300-350 for tv shops to fixed?That what it will cost for parts and labors by a professional tv tech. to do the job wright.
Jun 12, 2011 | Sony KP-57WS500 57" Rear Projection...
I have a Swift SM80 microscope and we are seeing double images. I can't seem to adjust
Sometimes the eyepiece tubes get out of alignment. To check for this, look through the microscope. As you are looking through the scope hold the eyepiece tubes and see slightly "flexing" these tubes with your hands has an affect on the image. If your head is the problem you will be able to flex the tubes until the image is clear. You won't need alot of force. Do not use enough force to bend or break the weak metal. If this works your eyetubes and or head are misaligned. Unfortunately, once a head has been misaligned like this it is not practically repairable.
Nov 01, 2010 | Swift SM95-90HF Stereoscopic Dissecting...
I was just given a samsung hcp4752wx/xaa. The
OK, Its always best to replace the lens assembly if its not preforming well. never dump the fluid. just replace the lens. As for the double images and the misalignment of the blue convergence line, this is caused by a faulty convergence chip that is located on the convergence board. you will need to replace this board in order to restore proper convergence performance.
May 16, 2009 | Samsung Televison & Video
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Double image
yes you just need two ICs
Jul 12, 2008 | Akai PTH5498 54" Rear Projection...
Leica III camera focusing problem
Yes, if the vertical misalignment is small, say, about less than a tenth of the image size that is misaligned vertically, then try rotating the 'lens' that covers the front left (as viewed from front of camera body, in upright position) rangefinder window.That is, the front RF window near the slow speed setting dial. In order to do so, you will need to unscrew the decorative chrome bezel first. Unscrew in counterclockwise direction. Do not use pliers, etc. to remove bezel, or you will possibly distort and/or mar the chrome finish. Instead wrap bezel with two, or three layers of making tape, making certain masking tape is not contacting the body of the camera, but only the bezel. Usually, bezel can now be unscrewed by hand only; if not, use pliers gently with the masking tape acting to protect the bezel's finish. Once the bezel is off, the lens (it's actually a glass wedge prism) can be rotated using the prongs of a tweezer inserted in the two notches of the brass ring encompassing the 'lens', or glass wedge. First, rotate in both directions, cw and ccw, in small angles to determine which direction and how much wedge rotation is required to bring the two rangefinder images into coincidence vertically. Reassemle in the reverse order.
May 19, 2007 | Leica IIIg 35mm SLR Camera
The picture has a double image.
All conections to the set need to be check very carefully starting form the cable to comes into the cable box from the outside and the cable that goes from the box to the tv,eliminate the cable box and conect the wire from outside direct in the tv and and see how it looks bring a small portable and conect the cable to it to see how it looks,once all the possibilities have eliminated then consider a problem inside the tv in the tuner area starting at the very conector where the cable conects.All this can help if the double image is not related to misaligned convergence.
Oct 01, 2006 | Hitachi 50V500 50 in. HD-Ready LCD...
Sylvania 6427FF TV Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
