Question about Electrical Supplies
Hard starting for 1300 series perkins generator
3 Suggested Answers
SOURCE: MY Perkins generator 2300 series crank but can not
2300 dce engine crank but not start
Posted on Jul 05, 2010
  • 8 Answers
SOURCE: What is the size Battery (cranking amp) needed for
Use a 120 amps battery
Posted on Jun 04, 2011
How to download ecm software for perkins engine DSE 404D.22 made in UK
my name is christian i m a gen technican based in abuja . pls i need some soft ware to repaire gen
Mar 04, 2014 | Miller 907175 Welder Generator Perkins...
ELECTRICITY PRESENTS BUT GENERATOR START IN AUTO MODE
You have the remote control wires incorrectly connected either at the ATS or on the generator control panel, disconenct from both ends and ohm them to make sure they are not shorted between. Then reconnect them at the generator end only. Then join them together manually, of the gen starts and stops when taken apart, the problem is in the transer switch, or incorrect terminated
Jun 14, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Perkins 3 cylinder powered pramac generator
Start looking at your safety circuits.
1. High water temp
2. Low Oil
3. Low water etc...
From the manual these are the protection circuits.
• Engine protection: low oil pressure, high engine temperature.
• Genset protection: under/over voltage, overload, battery charger failure, battery voltage out of limits,
under/over frequency, start failure.
• Circuit breaker protection: IV poles.
• Differential protection.
Any one of them will trip the fuel relay closed. What you may be able to do is disconnect one at a time each protection circuit and see when the fuel relay opens. (Make sure to reconnect each one if it had no effect on the fuel solenoid)
Once you isolate which circuit it is in then you can chase wires or change the bad switch.
Thanks for choosing FixYa.
Kelly
May 24, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
What is the size Battery (cranking amp) needed for a 3990cc 4 cylinder Perkins 50HP AA Series Naturally Asperated Diesel Engine With a 40KW Generator attached. Thanks, Verner From Florida.
If the unit has a battery box, measure it and get the largest size that will fit and of course the correct voltage. Diesels take a lot to crank.
You can search battery sizes on the internet for physical size. NAPA has a pretty good selection.
Apr 02, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
MY Perkins generator 2300 series crank but can not start
I take it it's diesel. Have you renewed filters? Bleed fuel system Make sure there is plenty of diesel flowing out of tank (pipe not blocked) Check lift pump working
Oct 22, 2009 | Electrical Supplies
Diesel mixed with oil in the sump
You run again the generator but before running, check & mark the oil level. Then stop the generator & wait until the oil settle to the bottom of oil pan. Check the oil level again & if the oil level is higher than the marking before that's means you have an engine gasket leak.You need to replace that gasket.
Mar 19, 2009 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Electrical Supplies Logo
51 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
